Question on Qubes docs "Using kernel installed in the VM"
Hello, I tried to follow instructions of Managing qube kernels | Qubes OS for a Debian 12 minimal template, but they are not quite clear to me:
  • First paragraph
    “Both debian-9 and fedora-26 templates already have grub and related tools preinstalled […]”
    sounds like this is only for full templates, so I continued.
  • qvm-clone debian-12-minimal deb-12-min-waydroid
  • Within template VM deb-12-min-waydroid:
    sudo apt install linux-image-amd64 linux-headers-amd64 grub2 qubes-kernel-vm-support
    sudo grub-install /dev/xvda # there was no auto-popup
  • Shutdown template
  • dom0 → Qubes VM Manger → right click on the VM → Qube settings → Advanced
  • Kept PVH virtualization, as docs say: “Virtualization mode PVH: Possible.” and PVH seems safer (more secure as well?) default than HVM.
  • Tried to change kernel to pvgrub2-pvh, as docs state:
    “If Virtualization is set to PVH → Kernel → choose pvgrub2-pvh → OK”
    , but there is no entry for this value.
  • Manually setting kernel:
    qvm-prefs deb-12-min-waydroid kernel pvgrub2-pvh
    results in
    Kernel ‘pvgrub2-pvh’ not installed
  • Setting kernel to (provided by qube) results at start in
    Qube deb-12-min-waydroid has failed to start: virt_mode PVH require kernel to bet set
  • Only docs’ very first instructions, which I thought are for full templates work:
    qvm-prefs deb-12-min-waydroid virt_mode hvm
    qvm-prefs deb-12-min-waydroid kernel ''
Could anyone clarify? Either I did something wrong or docs are unclear. Thanks!
You need to install grub2-xen-pvh in dom0 to use the in-VM kernel in PVH mode
sudo qubes-dom0-update grub2-xen-pvh
I guess the docs should be updated to clarify this.
Thanks @apparatus, this is good to know. With regards to grub2-xen-pvh: I’ll try HVM first with Waydroid, to keep dom0 as minimal as possible.
Is there any other way to contribute docs changes than with an existing GitHub account?
I’d like to edit that page based on your given answer, but I don’t have an account on said platform (and don’t want to make one either).
You can send the proposed changes to @unman:
Docs polishing - #4 by unman
