Question about Dell Hardware
I check the HCL and there are no reports similar to this
Here is the specs i’m going to get: Dell XPS 15 9500 15.6" 4K+ i7-10875H 32GB RAM Nvidia GTX 1650Ti
few questions
  1. Will qubes install
  2. will coreboot install
  3. will me cleaner work
if they wont, can you recommend a laptop similar that would?
Thanks
Very nice.
Yes.
Not sure. Only one way to find out :wink:
Probably not, but only one way to find out :wink:
ThinkPad X230 :stuck_out_tongue:
Ok, in all seriousness, this laptop shouldn’t give you any trouble on Qubes OS. The only thing that might give you grief is the nVIDIA GPU.
As for coreboot or the ME cleaner, that will depend on your chipset, and whether they’ve figured out your CPU. My guess would be that they haven’t yet, but you’re better off asking the Coreboot project.
If you do install, please submit an HCL to help the community :slight_smile:
Any issues, just ask!
thank you
