TailsOS offers privacy for Electrum from a bootable USB, however I’m curious if maybe Qubes Vault with Electrum from a bootable USB may offer privacy and security?
Handy if travelling to have the USB cold wallet, to top up the hot wallet on the phone.
If both are offline, in my opinion the difference is minimal. Tails will be way more comfortable to use in these conditions.
Qubes OS on an USB device is a bit of a pain to setup, and due to its heavy disk input/output you may have terrible performance, if you use an USB memory stick, it may die “quickly” due to wear (this depends on multiple factors though).
I installed it on a external NVMe SSD and after using it two times it doesn’t boot anymore… Maybe I had only had bad luck, but I then installed on the internal NVMe…
Does Electrum not require tor and networking to connect to block chain? Vault does not have networking. Whonix WS does and has a crypto wallet which seems to be what you are interested it. It’s not a bank Vault as banks require transacting. More like a key or document cell.
Persistence in TAILS is like a Vault you can choose to have networking or not (but you can also change Vault which defeats the purpose of Vault).
Qubes is all about controlling access: what PCI, networking or not, what level of rw permissions, etc.
I would either do TAILS persist for crypto or have a Qubes that is just the best hardened host for Whonix and that you don’t modify much otherwise since it may become vulnerable if you do whereas that is a lot less likely in TAILS.
