yeah in dom0…my output is the same
luv it…No this is great, you show me, like you just did..but in a standalone qube.
This time Send a file to a standaloneVM from an appVM and show me where it lands in the standaloneVM.(screenshot of file in the folder or/full/path) I get output it lands but not where..
Same goes for ‘copy to qube tool’ But only for standaloneVM as target.
and i cant copy paste text …special qubes procedure isnt working…after paste hits local clipboard (notice from global clipboard) local is cleared everytime… so i was hopin the tool could help me copy/paste but i still cant do it between qubes…
super frustrating and i thought the tool was my savior…
but i still cant get the third step to paste…So it has to be me misunderstanding the third step (Ctrl V)
there is something im missing…Im gonna do a quick screen vid to talk through my steps, i dont think my written description helps someone understand/ just need a mic, and how do i run obs-studio in dom0?
I agree with this, thanks. Installing these things in dom0 is against the qubes security model.
An ‘admin’ qube seems the way to go. That said, there are quite a few of guides like this out there (installed in dom0) but I don’t see any guides with similar capabilities on a qube like an admin qube.
Perhaps a guide or some solutions to the issues the OP raised about the current limitations of executing these commands from an ‘admin qube’ would be very welcome and solve not just this but what seems to me to be a much broader class of issues.
I think you’d happily use the admin GUI tools in dom0, which also increase the attack surface. Otherwise, we should only use CLI instead of GUI python in dom0. Dom0 will have more and more GUI tools with each new version to make things easier for beginners. So, I’m confident that such a useful control panel will appear in Qubes. And I’d like the devs to add it, since the user has done a huge amount of work
honestly, I haven’t properly gotten to it yet. I did make a start, there’s a first version that meets the criteria, but it isn’t fully working yet and needs more testing. right now I don’t have the time for it, as I’m focused on paid work that has to come first
a current, fully working and tested version is already available on GitHub for anyone who wants to use it
This is a concept I have struggled before to trtuely understand, I think you are thinking more of the sys-admin style than sys-gui. Been a couple of threads about the admin api and how you can have many sys-sdmin style qubes.
Looks great. It would probably make life much easier because I don’t like typing a million lines of commands into the terminal for something a GUI can do in seconds.
Lol, sounds like someone needs to take their own advice.
Careful, you speak so confidently that people might think you know what you’re talking about. Can you provide proof of this statement? I can prove that its false.
root@dom0:~# truncate -s 10G /media/vm-pool/test.img
root@dom0:~# mkfs.btrfs -L pool-nest /media/vm-pool/test.img
btrfs-progs v6.17.1
See https://btrfs.readthedocs.io for more information.
Label: pool-nest
UUID: a6431572-655e-4817-bc7b-1dcfa1ccea25
Node size: 16384
Sector size: 4096 (CPU page size: 4096)
Filesystem size: 10.00GiB
Block group profiles:
Data: single 8.00MiB
Metadata: DUP 256.00MiB
System: DUP 8.00MiB
SSD detected: no
Zoned device: no
Features: extref, skinny-metadata, no-holes, free-space-tree
Checksum: crc32c
Number of devices: 1
Devices:
ID SIZE PATH
1 10.00GiB /media/vm-pool/test.img
root@dom0:~# losetup --show -f /media/vm-pool/test.img
/dev/loop63
root@dom0:~# mount -m /dev/loop63 /media/pool-nest
root@dom0:~# qvm-pool add -o dir_path=/media/pool-nest nested-pool file-reflink
root@dom0:~# qvm-pool list
NAME DRIVER
varlibqubes file-reflink
linux-kernel linux-kernel
vm-pool file-reflink
I probably sound a little acerbic. It bothers me when people confidently say things that are not true and on top of that while berating someone else.
@whoqubes It can be, depends on your setup. If your dom0 filesystem is on LVM and you have free space in the VG, then you can resize the dom0 root LV and then resize the filesystem.
But if you want to create a pool on top of your vm-pool, its possible using a variation of the commands above. If vm-pool is an LV, you might prefer to create another LV for the new pool, instead of nesting the pool. Nested pools should have worse performance compared to non-nested, but depending on your usage you might not notice it.
I really hope this project gets integrated into Qubes dom0 in some way. It’s excellent and makes Qubes so much easier. I hope the Qubes team reaches out to this person or somehow there is progress on this. This is the best interface improvement to using Qubes I have seen during the entire time I’ve used Qubes, which extends for years.
I am also noticing that with ephemeral qubes, they do not automatically shut down and the settings say they are missing the qubes-app-shutdown-idle package. i did try installing the package in the template and it didn’t change things.
thank you so much! it’s really great to hear that people are enjoying it. to be honest, i haven’t had a chance to work on the project since mid september. i’m currently short on both time and resources, and i do everything from development to testing on the same device. i can’t afford a second device right now, but one is really necessary to continue developing the project. but please feel free to share any ideas, and once i have the time and the equipment i need, i’ll continue working on it!
saludos
