I know it is not a good idea to make sys-whonix disposable, because that would cause the tor state to be lost on every boot, which is bad for privacy.
I know that if sys-net is disposable, I will have to re-enter my Wi-Fi password. This is not a problem for me. Any other issues?
I don’t see any problems with sys-usb, please correct me if I’m wrong.
Now the interesting question. What about sys-firewall? How does it handle the qvm-firewall commands I set in dom0? Are they loaded into sys-firewall once, at each boot, or are they not processed in sys-firewall at all? Would I lose some rules? I am not sure how the QubesOS firewall is processed and for that reason I am also not sure about sys-firewall. Please explain, thanks!
sys-net: Strictly speaking if you’re willing to store your WiFi password on the disposable template, you won’t have to re-enter it every time.
Another possibility would be to keep it on dom0 and send it to the disposable on startup; you could even encrypt that connection. That avoids it being stored in the clear on your sys-net (unless the networking software itself does so). This would involve writing qrexec services and so forth, but is doable.
The rules are stored in dom0 and are accessible in the firewall qubes from dom0 using QubesDB.
I am a simple man, I keep my Wi-Fi passwords in my vault KeePassXC and copy it when I need it. I am on Ethernet 98% of the year anyway.
So it would not matter if sys-firewall is disposable because the QubesDB is persistent and the rules are copied every time it starts? Or is QubesOS even smarter and sys-firewall has some sort of connection to QubesDB by default (without a copy)?
When the firewall rules are updated in dom0 the sys-firewall will see the changes and apply them.
And that’s exactly what I do for stuff I use infrequently!
In my case I use WiFi a lot (it’s my only route to the internet) so I wanted a more automated solution. Anyhow, I thought I’d throw that out there just in case you (or anyone else reading this) found entering the password to be a frequent annoyance.
Here’s hoping you get qubes set up exactly how you like!
Thanks for the info. But what if I set rules before and sys-firewall is disposable? Will I lose my rules?
The firewall rules are stored in dom0.
And sys-firewall loads those on startup?
Yes.
