Hi there,
I did a fresh (default) installation of QubesOS R4.2.0 on a HPE Z240 (latest BIOS) with Intel Xeon E3-1240v5, 32GB RAM, NVidia Quadro K620 graphics card. Memtest was executed for several days without problems.
I am using a KVM switch (USB and graphics card connection) to switch between 2 computers.
I have the problem that QubesOS freezes after some time. I am working on the other computer and when switching back to QubesOS xfce is freezed. But: I am still able to move the mouse and see the mouse pointer moving. I am unable to click on any window or to enter text.
I am also able to login to cli by pressing Ctrl+Alt+F4. Changing back with Ctrl+Alt+F1 does not change anything.
I did another install and disabled “Use a qube to hold all USB controllers” (sys-usb) - this didn’t change anything, freeze is still there.
I checked the logs in /var/log/xen/console and /var/log/Xorg.0.log, but did not find any cause for the freeze.
Is there anything more I can do/check to find the cause for the freeze?
Best regards,
cyb
