Qubes won't show login screen after changed default-dvm
How do I fix a corrupted qubes OS I was in the cubes config and I changed the default disposable to a copied version of the default-dvm now when I start up the PC it will just have a loading bar on the log in screen forever
Does anyone know how I can fix this and change it back to the default - dvm
Sorry to hear this happened to you. My assumption is that it failed to start the various sys-* qubes and now it is hanging.
Can you hit esc while it is loading and share some details at the bottom? It should show lots of text.
note your post was auto-flagged for some reason. so it got hung up in the moderation queue for a day. sorry
I have also made the title a bit more soecific to youe problem, so others can have an easier time understanding before clicking.
Try to disable the qubes autostart on boot like this:
Then you can change the default disposable template back to default-dvm.
