Qubes, with Xen Hypervisor Boot Issue - Black Screen
Hello, I recently installed Qubes OS but whenever I select “Qubes, with Xen hypervisor” in GRUB it does:
Loading Xen…
Loading Linux…
Loading initial ramdisk…
0x0000… bytes at- cuts off and goes to a black screen. I think it crashes/freezes. Anyone know how to fix this? New to linux so sorry if question is a bit unclear/is missing information.
Using Qubes OS version: 4.2.4
Hardware: Acer Aspire 3 (A315-24P)
Do you have access to other virtual terminals with ctrl+alt+f[2-6] after booting to black screen?
Maybe you could troubleshoot from there. Otherwise you could try using serial port for troubleshooting…
Also try connecting a monitor. This is completely out of pocket but what if will display image there for whatever reason.
No
My laptop and monitor don’t have serial ports
Tried with an HDMI cable but my monitor said “HDMI NO INPUT”
I appreciate your help. I am new to linux so troubleshooting this is difficult for me… Also, I added more information to my initial post
Usb is a serial port, you should be able to use it:
https://www.kernel.org/doc/html/latest/admin-guide/serial-console.html
Of course, this is for generic linux, qubes’ dom0 is under xen, so you could try debugging xen too:
It also may cut your screen off to try and show a pretty image, there is a way to disable that to allow linux to display boot messages on screen, like this:
