I do not see an entry for alpha_support when I run the modinfo command you specified.
However neither do I see anything related in journalctl either positive or negative so it’s possible that I didn’t update grub correctly. I updated the grub config file then grub2-mkconfig then dracut -f. Is this the correct method?
I only have one monitor attached at a time. I’m having all the issues when the 4K one is attached. When it finally gets through the login there is no right click and no toolbar so it’s not possible to change any settings.
I know. But the symptoms of my problem are that the entire bit process is messed but but once I actually get to log in i have no toolbar or right click so whatever options there are cannot be relevant to my issue
