Qubes/VMs won't show up
None of my Qubes show any GUI, unrelated to the template, every Qube. I just messed up with lightdm and my graphic drivers, never consiouslly build a sys-gui. Dom0 just works fine.
Any idea where I can search for the root of the problem?
Hmm, apps have GUIs, Qubes haven’t an own GUI.
I suspect this is related to the way you’ve fixed the lightdm issue
Just want to add that tray icons from qubes won’t show up either, those from Dom0 do. Also sddm+kde won’t do the job either, there is no error message.
Well, qubes-gui-daemon was uninstalled.
Now my secure clipboard is broken and I get those error messages, but technically the initial problem is solved.
It sounds like @otter2 was correct.
Do you know how it happened? Was there a bad guide somewhere?
Or a dnf remove?
