I have a Kali HVM that was working good. I wanted to setup qrexec agent on it. So I installed a few of qubes core packages on Kali HVM. I installed qubes-usb-proxy, qubes-core-qrexec, qube-core-agent. It required a few more qubes packages as dependencies like qubesdb.etc. The installation was successful and I double checked the qrexec, core-agent daemons were successfully running. So everything was good so far. I was able to attach usb devices to HVM, copy to other Vm from HVM…etc… However, something got messed up in Xorg-server. I’m not sure what exactly happened. Now every time I boot into HVM, I have to login through tty then type “startx” for xinit to pull up desktop environment. I already double checked a few different DE, gdm, lightdm to rule out DE. They all worked when I typed startx in tty. So it’s not the DE. I believe it’s something in xorg. This is my Xorg.0.log. Any help is really appreciated.
[ 9463.486]
X.Org X Server 1.20.8
X Protocol Version 11, Revision 0
[ 9463.486] Build Operating System: Linux 4.19.0-8-amd64 x86_64 Debian
[ 9463.486] Current Operating System: Linux Kali-bad-clone-test-with-qubes 5.8.0-kali1-amd64 #1 SMP Debian 5.8.7-1kali1 (2020-09-14) x86_64
[ 9463.486] Kernel command line: BOOT_IMAGE=/vmlinuz-5.8.0-kali1-amd64 root=/dev/mapper/blackB0x–vg-root ro initrd=/install/initrd.gz quiet splash
[ 9463.486] Build Date: 31 March 2020 10:14:40AM
[ 9463.486] xorg-server 2:1.20.8-2 (https://www.debian.org/support)
[ 9463.486] Current version of pixman: 0.36.0
[ 9463.486] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 9463.486] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 9463.486] (==) Log file: “/home/ka3dcl/.local/share/xorg/Xorg.0.log”, Time: Mon Sep 28 21:11:49 2020
[ 9463.486] (==) Using config file: “/etc/X11/xorg.conf”
[ 9463.486] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 9463.486] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 9463.487] (==) ServerLayout “X.org Configured”
[ 9463.487] () |–>Screen “Screen0” (0)
[ 9463.487] () | |–>Monitor “Monitor0”
[ 9463.487] () | |–>Device “Card0”
[ 9463.487] () |–>Input Device “Mouse0”
[ 9463.487] () |–>Input Device “Keyboard0”
[ 9463.487] (==) Automatically adding devices
[ 9463.487] (==) Automatically enabling devices
[ 9463.487] (==) Automatically adding GPU devices
[ 9463.487] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 9463.487] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 9463.487] Entry deleted from font path.
[ 9463.487] () FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins,
built-ins
[ 9463.487] () ModulePath set to “/usr/lib/xorg/modules”
[ 9463.487] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 9463.487] (WW) Disabling Mouse0
[ 9463.487] (WW) Disabling Keyboard0
[ 9463.487] (II) Loader magic: 0x5592d69c0e20
[ 9463.487] (II) Module ABI versions:
[ 9463.487] X.Org ANSI C Emulation: 0.4
[ 9463.487] X.Org Video Driver: 24.1
[ 9463.487] X.Org XInput driver : 24.1
[ 9463.487] X.Org Server Extension : 10.0
[ 9463.488] (++) using VT number 2
[ 9463.489] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 9463.490] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 9463.491] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 9463.498] (–) PCI:*(0@0:3:0) 1234:1111:1af4:1100 rev 2, Mem @ 0xf1000000/16777216, 0xf2024000/4096, BIOS @ 0x???/131072
[ 9463.498] (II) “glx” will be loaded. This was enabled by default and also specified in the config file.
[ 9463.498] (II) LoadModule: “glx”
[ 9463.498] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 9463.499] (II) Module glx: vendor=“X.Org Foundation”
[ 9463.499] compiled for 1.20.8, module version = 1.0.0
[ 9463.499] ABI class: X.Org Server Extension, version 10.0
[ 9463.499] (II) LoadModule: “modesetting”
[ 9463.499] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 9463.499] (II) Module modesetting: vendor=“X.Org Foundation”
[ 9463.499] compiled for 1.20.8, module version = 1.20.8
[ 9463.499] Module class: X.Org Video Driver
[ 9463.499] ABI class: X.Org Video Driver, version 24.1
[ 9463.499] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 9463.499] (II) modeset(0): using drv /dev/dri/card0
[ 9463.499] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 9463.499] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 9463.499] (==) modeset(0): RGB weight 888
[ 9463.499] (==) modeset(0): Default visual is TrueColor
[ 9463.499] (II) Loading sub module “glamoregl”
[ 9463.499] (II) LoadModule: “glamoregl”
[ 9463.499] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 9463.501] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 9463.501] compiled for 1.20.8, module version = 1.0.1
[ 9463.501] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9463.558] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 9463.558] (EE) modeset(0): glamor initialization failed
[ 9463.558] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 9463.559] (II) modeset(0): Output Virtual-1 using monitor section Monitor0
[ 9463.559] (II) modeset(0): EDID for output Virtual-1
[ 9463.559] (II) modeset(0): Printing probed modes for output Virtual-1
[ 9463.559] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz eP)
[ 9463.559] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1400x1050"x60.0 121.75 1400 1488 1632 1864 1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1400x1050"x59.9 101.00 1400 1448 1480 1560 1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1366x768"x59.8 85.50 1366 1436 1579 1792 768 771 774 798 +hsync +vsync (47.7 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1366x768"x60.0 72.00 1366 1380 1436 1500 768 769 772 800 +hsync +vsync (48.0 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1360x768"x60.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1280x768"x59.9 79.50 1280 1344 1472 1664 768 771 778 798 -hsync +vsync (47.8 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1280x768"x60.0 68.25 1280 1328 1360 1440 768 771 778 790 +hsync -vsync (47.4 kHz e)
[ 9463.559] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 9463.559] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 9463.559] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 9463.559] (II) modeset(0): Modeline "848x480"x60.0 33.75 848 864 976 1088 480 486 494 517 +hsync +vsync (31.0 kHz e)
[ 9463.559] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 9463.559] (II) modeset(0): Output Virtual-1 connected
[ 9463.559] (II) modeset(0): Using exact sizes for initial modes
[ 9463.559] (II) modeset(0): Output Virtual-1 using initial mode 1024x768 +0+0
[ 9463.559] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 9463.559] (==) modeset(0): DPI set to (96, 96)
[ 9463.559] (II) Loading sub module “fb”
[ 9463.559] (II) LoadModule: “fb”
[ 9463.559] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 9463.559] (II) Module fb: vendor=“X.Org Foundation”
[ 9463.559] compiled for 1.20.8, module version = 1.0.0
[ 9463.559] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9463.559] (==) modeset(0): Backing store enabled
[ 9463.559] (==) modeset(0): Silken mouse enabled
[ 9463.560] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 9463.560] (==) modeset(0): DPMS enabled
[ 9463.560] (II) Initializing extension Generic Event Extension
[ 9463.560] (II) Initializing extension SHAPE
[ 9463.560] (II) Initializing extension MIT-SHM
[ 9463.560] (II) Initializing extension XInputExtension
[ 9463.560] (II) Initializing extension XTEST
[ 9463.561] (II) Initializing extension BIG-REQUESTS
[ 9463.561] (II) Initializing extension SYNC
[ 9463.561] (II) Initializing extension XKEYBOARD
[ 9463.561] (II) Initializing extension XC-MISC
[ 9463.561] (II) Initializing extension SECURITY
[ 9463.561] (II) Initializing extension XFIXES
[ 9463.561] (II) Initializing extension RENDER
[ 9463.561] (II) Initializing extension RANDR
[ 9463.561] (II) Initializing extension COMPOSITE
[ 9463.561] (II) Initializing extension DAMAGE
[ 9463.561] (II) Initializing extension MIT-SCREEN-SAVER
[ 9463.562] (II) Initializing extension DOUBLE-BUFFER
[ 9463.562] (II) Initializing extension RECORD
[ 9463.562] (II) Initializing extension DPMS
[ 9463.562] (II) Initializing extension Present
[ 9463.562] (II) Initializing extension DRI3
[ 9463.562] (II) Initializing extension X-Resource
[ 9463.562] (II) Initializing extension XVideo
[ 9463.562] (II) Initializing extension XVideo-MotionCompensation
[ 9463.562] (II) Initializing extension SELinux
[ 9463.562] (II) SELinux: Disabled on system
[ 9463.562] (II) Initializing extension GLX
[ 9463.562] (II) AIGLX: Screen 0 is not DRI2 capable
[ 9463.568] (II) IGLX: Loaded and initialized swrast
[ 9463.568] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 9463.568] (II) Initializing extension XFree86-VidModeExtension
[ 9463.568] (II) Initializing extension XFree86-DGA
[ 9463.568] (II) Initializing extension XFree86-DRI
[ 9463.568] (II) Initializing extension DRI2
[ 9463.568] (II) modeset(0): Damage tracking initialized
[ 9463.568] (II) modeset(0): Setting screen physical size to 270 x 203
[ 9463.606] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 9463.606] () Power Button: Applying InputClass “libinput keyboard catchall”
[ 9463.606] (II) LoadModule: “libinput”
[ 9463.606] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 9463.608] (II) Module libinput: vendor=“X.Org Foundation”
[ 9463.608] compiled for 1.20.8, module version = 0.30.0
[ 9463.608] Module class: X.Org XInput Driver
[ 9463.608] ABI class: X.Org XInput driver, version 24.1
[ 9463.608] (II) Using input driver ‘libinput’ for ‘Power Button’
[ 9463.609] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 21 paused 0
[ 9463.609] () Power Button: always reports core events
[ 9463.609] () Option “Device” “/dev/input/event1”
[ 9463.609] () Option “_source” “server/udev”
[ 9463.611] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9463.611] (II) event1 - Power Button: device is a keyboard
[ 9463.611] (II) event1 - Power Button: device removed
[ 9463.611] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event1”
[ 9463.611] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 9463.611] () Option “xkb_model” “pc105”
[ 9463.611] () Option “xkb_layout” “us”
[ 9463.612] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9463.612] (II) event1 - Power Button: device is a keyboard
[ 9463.612] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 9463.612] () Sleep Button: Applying InputClass “libinput keyboard catchall”
[ 9463.612] (II) Using input driver ‘libinput’ for ‘Sleep Button’
[ 9463.613] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 24 paused 0
[ 9463.614] () Sleep Button: always reports core events
[ 9463.614] () Option “Device” “/dev/input/event2”
[ 9463.614] () Option “_source” “server/udev”
[ 9463.614] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 9463.614] (II) event2 - Sleep Button: device is a keyboard
[ 9463.614] (II) event2 - Sleep Button: device removed
[ 9463.615] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSLPBN:00/input/input3/event2”
[ 9463.615] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 7)
[ 9463.615] () Option “xkb_model” “pc105”
[ 9463.615] () Option “xkb_layout” “us”
[ 9463.616] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 9463.616] (II) event2 - Sleep Button: device is a keyboard
[ 9463.617] (II) config/udev: Adding input device QEMU QEMU USB Tablet (/dev/input/event3)
[ 9463.617] () QEMU QEMU USB Tablet: Applying InputClass “libinput pointer catchall”
[ 9463.617] (II) Using input driver ‘libinput’ for ‘QEMU QEMU USB Tablet’
[ 9463.747] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 25 paused 0
[ 9463.747] () QEMU QEMU USB Tablet: always reports core events
[ 9463.747] () Option “Device” “/dev/input/event3”
[ 9463.747] () Option “_source” “server/udev”
[ 9463.748] (II) event3 - QEMU QEMU USB Tablet: is tagged by udev as: Mouse
[ 9463.749] (II) event3 - QEMU QEMU USB Tablet: device is a pointer
[ 9463.749] (II) event3 - QEMU QEMU USB Tablet: device removed
[ 9463.749] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:04.0/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input5/event3”
[ 9463.749] (II) XINPUT: Adding extended input device “QEMU QEMU USB Tablet” (type: MOUSE, id 8)
[ 9463.749] () Option “AccelerationScheme” “none”
[ 9463.749] () QEMU QEMU USB Tablet: (accel) selected scheme none/0
[ 9463.749] () QEMU QEMU USB Tablet: (accel) acceleration factor: 2.000
[ 9463.749] () QEMU QEMU USB Tablet: (accel) acceleration threshold: 4
[ 9463.750] (II) event3 - QEMU QEMU USB Tablet: is tagged by udev as: Mouse
[ 9463.750] (II) event3 - QEMU QEMU USB Tablet: device is a pointer
[ 9463.751] (II) config/udev: Adding input device QEMU QEMU USB Tablet (/dev/input/mouse0)
[ 9463.751] (II) No input driver specified, ignoring this device.
[ 9463.751] (II) This device may have been added with another device file.
[ 9463.751] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 9463.751] () AT Translated Set 2 keyboard: Applying InputClass “libinput keyboard catchall”
[ 9463.751] (II) Using input driver ‘libinput’ for ‘AT Translated Set 2 keyboard’
[ 9463.753] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 26 paused 0
[ 9463.753] () AT Translated Set 2 keyboard: always reports core events
[ 9463.753] () Option “Device” “/dev/input/event0”
[ 9463.753] () Option “_source” “server/udev”
[ 9463.754] (II) event0 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 9463.754] (II) event0 - AT Translated Set 2 keyboard: device is a keyboard
[ 9463.754] (II) event0 - AT Translated Set 2 keyboard: device removed
[ 9463.754] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input0/event0”
[ 9463.754] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 9)
[ 9463.754] () Option “xkb_model” “pc105”
[ 9463.754] () Option “xkb_layout” “us”
[ 9463.755] (II) event0 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 9463.755] (II) event0 - AT Translated Set 2 keyboard: device is a keyboard
[ 9463.756] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/event4)
[ 9463.756] () ImExPS/2 Generic Explorer Mouse: Applying InputClass “libinput pointer catchall”
[ 9463.756] (II) Using input driver ‘libinput’ for ‘ImExPS/2 Generic Explorer Mouse’
[ 9463.757] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 27 paused 0
[ 9463.757] () ImExPS/2 Generic Explorer Mouse: always reports core events
[ 9463.757] () Option “Device” “/dev/input/event4”
[ 9463.757] () Option “_source” “server/udev”
[ 9463.758] (II) event4 - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[ 9463.758] (II) event4 - ImExPS/2 Generic Explorer Mouse: device is a pointer
[ 9463.758] (II) event4 - ImExPS/2 Generic Explorer Mouse: device removed
[ 9463.758] () Option “config_info” “udev:/sys/devices/platform/i8042/serio1/input/input4/event4”
[ 9463.758] (II) XINPUT: Adding extended input device “ImExPS/2 Generic Explorer Mouse” (type: MOUSE, id 10)
[ 9463.758] () Option “AccelerationScheme” “none”
[ 9463.758] () ImExPS/2 Generic Explorer Mouse: (accel) selected scheme none/0
[ 9463.758] () ImExPS/2 Generic Explorer Mouse: (accel) acceleration factor: 2.000
[ 9463.758] () ImExPS/2 Generic Explorer Mouse: (accel) acceleration threshold: 4
[ 9463.759] (II) event4 - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[ 9463.759] (II) event4 - ImExPS/2 Generic Explorer Mouse: device is a pointer
[ 9463.759] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/mouse1)
[ 9463.759] (II) No input driver specified, ignoring this device.
[ 9463.759] (II) This device may have been added with another device file.
[ 9463.760] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 9463.760] (II) No input driver specified, ignoring this device.
[ 9463.760] (II) This device may have been added with another device file.
[ 9479.615] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[ 9479.632] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 9521.502] (II) config/udev: Adding input device Jabra Elite Active 65t (AVRCP) (/dev/input/event6)
[ 9521.502] () Jabra Elite Active 65t (AVRCP): Applying InputClass “libinput keyboard catchall”
[ 9521.503] () Jabra Elite Active 65t (AVRCP): Applying InputClass “libinput keyboard catchall”
[ 9521.503] (II) Using input driver ‘libinput’ for ‘Jabra Elite Active 65t (AVRCP)’
[ 9521.506] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 50 paused 0
[ 9521.506] () Jabra Elite Active 65t (AVRCP): always reports core events
[ 9521.506] () Option “Device” “/dev/input/event6”
[ 9521.506] () Option “_source” “server/udev”
[ 9521.507] (II) event6 - Jabra Elite Active 65t (AVRCP): is tagged by udev as: Keyboard
[ 9521.507] (II) event6 - Jabra Elite Active 65t (AVRCP): device is a keyboard
[ 9521.507] (II) event6 - Jabra Elite Active 65t (AVRCP): device removed
[ 9521.507] () Option “config_info” “udev:/sys/devices/virtual/input/input10/event6”
[ 9521.507] (II) XINPUT: Adding extended input device “Jabra Elite Active 65t (AVRCP)” (type: KEYBOARD, id 11)
[ 9521.507] () Option “xkb_model” “pc105”
[ 9521.507] () Option “xkb_layout” “us”
[ 9521.507] (WW) Option “xkb_variant” requires a string value
[ 9521.507] (WW) Option “xkb_options” requires a string value
[ 9521.508] (II) event6 - Jabra Elite Active 65t (AVRCP): is tagged by udev as: Keyboard
[ 9521.508] (II) event6 - Jabra Elite Active 65t (AVRCP): device is a keyboard
[ 9760.026] (II) config/udev: removing device Jabra Elite Active 65t (AVRCP)
[ 9760.026] () Option “fd” “50”
[ 9760.026] (II) event6 - Jabra Elite Active 65t (AVRCP): device removed
[ 9760.029] (II) UnloadModule: “libinput”
[ 9760.029] (II) systemd-logind: releasing fd for 13:70
[ 9780.198] (II) config/udev: Adding input device Jabra Elite Active 65t (AVRCP) (/dev/input/event6)
[ 9780.198] () Jabra Elite Active 65t (AVRCP): Applying InputClass “libinput keyboard catchall”
[ 9780.198] (II) Using input driver ‘libinput’ for ‘Jabra Elite Active 65t (AVRCP)’
[ 9780.203] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 67 paused 0
[ 9780.203] () Jabra Elite Active 65t (AVRCP): always reports core events
[ 9780.203] () Option “Device” “/dev/input/event6”
[ 9780.203] () Option “_source” “server/udev”
[ 9780.208] (II) event6 - Jabra Elite Active 65t (AVRCP): is tagged by udev as: Keyboard
[ 9780.208] (II) event6 - Jabra Elite Active 65t (AVRCP): device is a keyboard
[ 9780.208] (II) event6 - Jabra Elite Active 65t (AVRCP): device removed
[ 9780.208] () Option “config_info” “udev:/sys/devices/virtual/input/input11/event6”
[ 9780.208] (II) XINPUT: Adding extended input device “Jabra Elite Active 65t (AVRCP)” (type: KEYBOARD, id 11)
[ 9780.208] () Option “xkb_model” “pc105”
[ 9780.208] () Option “xkb_layout” “us”
[ 9780.208] (WW) Option “xkb_variant” requires a string value
[ 9780.208] (WW) Option “xkb_options” requires a string value
[ 9780.218] (II) event6 - Jabra Elite Active 65t (AVRCP): is tagged by udev as: Keyboard
[ 9780.218] (II) event6 - Jabra Elite Active 65t (AVRCP): device is a keyboard
[ 13741.635] (II) config/udev: removing device Jabra Elite Active 65t (AVRCP)
[ 13741.641] () Option “fd” “67”
[ 13741.641] (II) event6 - Jabra Elite Active 65t (AVRCP): device removed
[ 13741.641] (II) UnloadModule: “libinput”
[ 13741.641] (II) systemd-logind: releasing fd for 13:70
[ 13949.195] (II) config/udev: Adding input device Jabra Elite Active 65t (AVRCP) (/dev/input/event6)
[ 13949.195] () Jabra Elite Active 65t (AVRCP): Applying InputClass “libinput keyboard catchall”
[ 13949.195] (II) Using input driver ‘libinput’ for ‘Jabra Elite Active 65t (AVRCP)’
[ 13949.197] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 50 paused 0
[ 13949.197] () Jabra Elite Active 65t (AVRCP): always reports core events
[ 13949.197] () Option “Device” “/dev/input/event6”
[ 13949.197] () Option “_source” “server/udev”
[ 13949.202] (II) event6 - Jabra Elite Active 65t (AVRCP): is tagged by udev as: Keyboard
[ 13949.202] (II) event6 - Jabra Elite Active 65t (AVRCP): device is a keyboard
[ 13949.203] (II) event6 - Jabra Elite Active 65t (AVRCP): device removed
[ 13949.203] () Option “config_info” “udev:/sys/devices/virtual/input/input12/event6”
[ 13949.203] (II) XINPUT: Adding extended input device “Jabra Elite Active 65t (AVRCP)” (type: KEYBOARD, id 11)
[ 13949.203] () Option “xkb_model” “pc105”
[ 13949.203] () Option “xkb_layout” “us”
[ 13949.203] (WW) Option “xkb_variant” requires a string value
[ 13949.203] (WW) Option “xkb_options” requires a string value
[ 13949.205] (II) event6 - Jabra Elite Active 65t (AVRCP): is tagged by udev as: Keyboard
[ 13949.205] (II) event6 - Jabra Elite Active 65t (AVRCP): device is a keyboard
[ 15057.084] (II) config/udev: Adding input device C-Media Electronics Inc. USB Audio Device (/dev/input/event7)
[ 15057.084] () C-Media Electronics Inc. USB Audio Device: Applying InputClass “libinput keyboard catchall”
[ 15057.084] (II) Using input driver ‘libinput’ for ‘C-Media Electronics Inc. USB Audio Device’
[ 15057.105] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 63 paused 0
[ 15057.105] () C-Media Electronics Inc. USB Audio Device: always reports core events
[ 15057.105] () Option “Device” “/dev/input/event7”
[ 15057.105] () Option “_source” “server/udev”
[ 15057.106] (II) event7 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 15057.106] (II) event7 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 15057.109] (II) event7 - C-Media Electronics Inc. USB Audio Device: device removed
[ 15057.109] () Option “config_info” “udev:/sys/devices/platform/vhci_hcd.0/usb2/2-2/2-2:1.3/0003:0D8C:0014.0002/input/input13/event7”
[ 15057.109] (II) XINPUT: Adding extended input device “C-Media Electronics Inc. USB Audio Device” (type: KEYBOARD, id 12)
[ 15057.109] () Option “xkb_model” “pc105”
[ 15057.109] () Option “xkb_layout” “us”
[ 15057.109] (WW) Option “xkb_variant” requires a string value
[ 15057.109] (WW) Option “xkb_options” requires a string value
[ 15057.112] (II) event7 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 15057.112] (II) event7 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 15411.169] (II) config/udev: removing device Jabra Elite Active 65t (AVRCP)
[ 15411.169] () Option “fd” "[ 9463.486]
built-ins,
built-ins
[ 9463.487] (**) ModulePath set to “/usr/lib/xorg/modules”
[ 9463.559] (II) modeset(0): Modeline “640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 15411.169] (**) Option “fd” “50”
[ 15411.169] (II) event6 - Jabra Elite Active 65t (AVRCP): device removed
[ 15411.169] (II) UnloadModule: “libinput”
[ 15411.169] (II) systemd-logind: releasing fd for 13:7050”
(Attachment Xorg.0.log is missing)
