Hi Team,
I am facing an issue with “Qubes release 4.1.2”.
Its like I am not able to connect to Wifi (no Wifi connection option available).
Also, not able to see any bluetooth option.
For wifi, I was able to see below error in sys-net qube:-
so I tried to install linux-firmware and backport-iwlwifi as per the first answer here, and as I am newbie to Linux, so I tried to follow steps for installation of backport-iwlwifi as per this, but no luck.
I tried to install these above two firmwares on sys-net qube, which didn’t make any impact, later I performed these 2 firmware installation on debian 11 template qube, and after this, sys-net qube started throwing this error and didn’t start:-
I remember the kernel version was something like 5.15.xx on my machine.
My PC configuration is like as follows:-
CPU: Intel i5 13600K
Motherboard: ASUS TUF Gaming Z790 PLUS WIFI
RAM: 32 GB
SSD: 1TB
Please suggest what should I do? Should I wait for Qubes 4.2 release or some other fix can be applied manually at my end ?
Thanks and Regards
Rahul
