Updating whonix-gw-15
Error on updating whonix-gw-15: Command '['sudo', 'qubesctl',
'--skip-dom0', '--targets=whonix-gw-15', '--show-output', 'state.sls',
'update.qubes-vm']' returned non-zero exit status 1
whonix-gw-15: ERROR (exception list index out of range)
Updating whonix-ws-15
Error on updating whonix-ws-15: Command '['sudo', 'qubesctl',
'--skip-dom0', '--targets=whonix-ws-15', '--show-output', 'state.sls',
whonix-ws-15: ERROR (exception list index out of range)
Thank you Andrew. But since their "solution" seems to use Fedora instead
of Debian, one could also suggest re-installing qubes first to see if
the error persists, or changing the computer -- I exaggerate to
illustrate that this can not even be called a workaround :-))
Anyways. Whonix still allows manual update in terminal, maybe the
qubes-updater is overestimated anyways ... there were some nice scripts
under 3.2 for automatically updating all templates. Just have to find
hem again. Bernhard
