System Qubes(R4.0)
My whonix 16 randomly stopped working. I tried clicking on the apps but they won’t open.
My attempts to fix it
Update through qubes manger= failed and I can’t open any whonix 16 app including the terminal
Install whonix 17= “qvm-template command not found” yes I updated dom0
Upgrade to qubes R4.2
The postintstall stops after creating the recovery template
I still have my whonix 15 templates. Can I install 17 from there and is there a way to extract my whonix 16 files? I want to avoid doing a clean install because it was a headache setting everything up but if it’s my only option so be it.
