Dear Qubes Community,
Whonix 15 has reached EOL (end-of-life). If you have not already done
so, we strongly recommend upgrading your Whonix 15 templates and
standalones to Whonix 16 [1] immediately. The Whonix Project provides
fresh Whonix 16 template packages through the Qubes community template
repositories, which you can install in dom0 by following the standard
installation instructions [2]. Alternatively, the Whonix Project also
provides step-by-step instructions for performing an in-place upgrade
[3] of an existing Whonix 15 template. After upgrading your templates,
please remember to switch all qubes that were using the old template
to use the new one [4].
For a complete list of template releases supported for your specific
Qubes release, please see our supported template releases [5].
[1] Whonix 16 template available | Qubes OS
[2] How-to: Install the Stable Version of Qubes-Whonix ™ 16
[3] Release Upgrade Whonix 15 to Whonix 16 - Whonix
[4] Templates | Qubes OS
[5] Supported releases | Qubes OS
