When using the Salt user configuration located in '/srv/user_salt' what is the best way to use the Qubes specific pillars located (for this example) in '/srv/salt/_pillar'?
The below script should give you the idea how to do it:
Thank you very much for sharing this script.
I would prefer very much to do it in a Salt way rather than symlinking directories. It seems that this is possible in Saltstack and it's mentioned in the Management stack documentation of Qubes here: Salt (management software) | Qubes OS
"For each target you can write a list of state files. Each line is a path to a state file (without the .sls extension) relative to the main directory. Each / is exchanged with a ., so you can’t reference files or directories with a . in their name."
Any directions on how can I include the base PATH of the pillars '/srv/salt' to the top or sls file?
