I bolded the relevant terminal text
N: Download is performed unsandboxed as root as file ‘/home/user/Downloads/google-earth-pro-stable_current_amd64.deb’ couldn’t be accessed by user ‘_apt’. - pkgAcquire::Run (13: Permission denied)
What does this mean? Did the program fail to install? Do I need to install it to my template VM? What should I do? FYI: I’ve done my best to install everything to the OSINT qube alone but idk if this particular install got through.
user@OSINT-template-debian:~/Downloads$ sudo apt install -y ./google-earth-pro-stable_current_amd64.deb
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘google-earth-pro-stable’ instead of ‘./google-earth-pro-stable_current_amd64.deb’
The following packages were automatically installed and are no longer required:
python-numpy python-olefile python-pil python-pkg-resources
Use ‘sudo apt autoremove’ to remove them.
The following additional packages will be installed:
libglu1-mesa
The following NEW packages will be installed:
google-earth-pro-stable libglu1-mesa
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 169 kB/56.2 MB of archives.
After this operation, 250 MB of additional disk space will be used.
Get:1 https://deb.debian.org/debian buster/main amd64 libglu1-mesa amd64 9.0.0-2.1+b3 [169 kB]
Get:2 /home/user/Downloads/google-earth-pro-stable_current_amd64.deb google-earth-pro-stable amd64 7.3.3.7786-r0 [56.1 MB]
Fetched 169 kB in 1s (236 kB/s)
Selecting previously unselected package libglu1-mesa:amd64.
(Reading database … 134496 files and directories currently installed.)
Preparing to unpack …/libglu1-mesa_9.0.0-2.1+b3_amd64.deb …
Unpacking libglu1-mesa:amd64 (9.0.0-2.1+b3) …
Selecting previously unselected package google-earth-pro-stable.
Preparing to unpack …/google-earth-pro-stable_current_amd64.deb …
Unpacking google-earth-pro-stable (7.3.3.7786-r0) …
Setting up libglu1-mesa:amd64 (9.0.0-2.1+b3) …
Setting up google-earth-pro-stable (7.3.3.7786-r0) …
xdg-desktop-menu: No writable system menu directory found.
Processing triggers for mime-support (3.62) …
Processing triggers for libc-bin (2.28-10) …
Processing triggers for man-db (2.8.5-2) …
Processing triggers for qubes-core-agent (4.0.61-1+deb10u1) …
Processing triggers for desktop-file-utils (0.23-4) …
