Hi, fresh installation of R4.1.1 on a ThinkPad P14s (latest BIOS version) with:
[x] Use sys-net qube for both networking and USB devices
(Because I want to use USB Wifi since the built-in Wifi does not work, which is "Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz".)
'qvm-start sys-net' hits me with:
Start failed: internal error: Unable to reset PCI device 0000:00:14.0: internal error: Unable to reset PCI device 0000:00:0d.2: internal error: Unable to reset PCI device 0000:00:1f.6: internal error: Unable to reset PCI device 0000:00:0d.3: internal error: Unable to reset PCI device 0000:00:0d.0: no FLR, PM reset or bus reset available, see /var/log/libvirt/libxl/libxl-driver.log for details
Remedy found by trial-and-error:
qvm-pci detach sys-net dom0:00_0d.0
qvm-pci detach sys-net dom0:00_0d.2
qvm-pci detach sys-net dom0:00_0d.3
qvm-pci detach sys-net dom0:00_14.0
qvm-pci detach sys-net dom0:00_1f.6
qvm-pci attach --persistent --option no-strict-reset=true sys-net dom0:00_14.0
Output of 'qvm-pci', reduced to relevant 5 devices:
dom0:00_0d.0 USB controller: Intel Corporation Tiger Lake-LP Thunderbolt 4 USB Controller
dom0:00_0d.2 USB controller: Intel Corporation Tiger Lake-LP Thunderbolt 4 NHI #0
dom0:00_0d.3 USB controller: Intel Corporation Tiger Lake-LP Thunderbolt 4 NHI #1
dom0:00_14.0 USB controller: Intel Corporation Tiger Lake-LP USB 3.2 Gen 2x1 xHCI Host Controller sys-net (no-strict-reset=true)
dom0:00_1f.6 Ethernet controller: Intel Corporation Ethernet Connection (13) I219-LM
*Question:* is this a solid setup? (It works so far.)
Documentation reads: "While using the no-strict-reset flag, do not require PCI device to be reset before attaching it to another VM. This may leak usage data even without malicious intent."
As far as I see, the Host Controller (00_14.0) is attached to sys-net once after the system starts and then stays attached there; that's it. Is the warning about leaking usage data still relevant in such a case?
Thanks.
