root@host:/home/user# systemctl status tor@default
● tor@default.service - Anonymizing overlay network for TCP
Loaded: loaded (/lib/systemd/system/tor@default.service; enabled-runtime; vendor preset: enabled)
Drop-In: /usr/lib/systemd/system/tor@default.service.d
└─30_clean-torrc-d-on-reload.conf, 30_qubes.conf, 40_obfs4proxy-workaround.conf, 40_qubes.conf, 50_controlsocket-workaround.conf
Active: failed (Result: exit-code) since Mon 2021-04-19 01:27:12 UTC; 1min 3s ago
Process: 1468 ExecStartPre=/usr/bin/install -Z -m 02755 -o debian-tor -g debian-tor -d /run/tor (code=exited, status=0/SUCCESS)
Process: 1469 ExecStartPre=/usr/bin/tor --defaults-torrc /usr/share/tor/tor-service-defaults-torrc -f /etc/tor/torrc --RunAsDaemon 0 --verify-config (code=exited, status=
Process: 1470 ExecStart=/usr/bin/tor --defaults-torrc /usr/share/tor/tor-service-defaults-torrc -f /etc/tor/torrc --RunAsDaemon 0 (code=exited, status=1/FAILURE)
Main PID: 1470 (code=exited, status=1/FAILURE)
Apr 19 01:27:12 host tor[1470]: Apr 19 01:27:12.298 [notice] Closing partially-constructed HTTP tunnel listener connection (ready) on 10.137.0.48:9228
Apr 19 01:27:12 host tor[1470]: Apr 19 01:27:12.298 [notice] Closing partially-constructed HTTP tunnel listener connection (ready) on 10.137.0.48:9229
Apr 19 01:27:12 host tor[1470]: Apr 19 01:27:12.298 [warn] Failed to parse/validate config: Failed to bind one of the listener ports.
Apr 19 01:27:12 host tor[1470]: Apr 19 01:27:12.298 [err] Reading config failed–see warnings above.
Apr 19 01:27:12 host systemd[1]: tor@default.service: Service RestartSec=100ms expired, scheduling restart.
Apr 19 01:27:12 host systemd[1]: tor@default.service: Scheduled restart job, restart counter is at 5.
Apr 19 01:27:12 host systemd[1]: Stopped Anonymizing overlay network for TCP.
Apr 19 01:27:12 host systemd[1]: tor@default.service: Start request repeated too quickly.
Apr 19 01:27:12 host systemd[1]: tor@default.service: Failed with result ‘exit-code’.
Apr 19 01:27:12 host systemd[1]: Failed to start Anonymizing overlay network for TCP.
journalctl -ex
– A start job for unit sdwdate.service has begun execution.
