I tried to follow carefully the split-ssh instructions on
but I experience a stupid error. I did a "plain setup" without keepass.
So when I run
ssh-add -L in vault it does work, and has 1 test-identity.
ssh-add -L in work it does not work "Error connecting to
agent: Connection refused"
even with "-v -v -v" I get no better hint. So I tried to follow the traces;
1.) This happens when I ("manually") run
user@work:~$ bash -x /etc/qubes-rpc/qubes.SSHagent
++ qubesdb-read /name
+ notify-send '[work] SSH agent access from: dom0'
+ socat - UNIX-CONNECT:/home/user/.SSH_AGENT_sshkeys
2023/06/21 11:24:59 socat[1562] E connect(, AF=1
"/home/user/.SSH_AGENT_sshkeys", 34): Connection refused
you may observe that I wrote SSH with 3 capital letters, but I did so
everywhere (I hope :), inclusive the small script snipplets from github
page.
2.) This happens when I query the ssh agent:
systemctl --user status ssh-agent.service
● ssh-agent.service - OpenSSH Agent
Loaded: loaded (/usr/lib/systemd/user/ssh-agent.service; static)
Active: active (running) since Wed 2023-06-21 11:18:46 CEST; 22min ago
Docs: man:ssh-agent(1)
Main PID: 1513 (ssh-agent)
Tasks: 1 (limit: 4618)
Memory: 872.0K
CPU: 3ms
CGroup:
/user.slice/user-1000.slice/user@1000.service/app.slice/ssh-agent.service
└─1513 ssh-agent -D -a /run/user/1000/openssh_agent
Jun 21 11:18:46 work systemd[654]: Started ssh-agent.service - OpenSSH
Agent.
Jun 21 11:18:46 work agent-launch[1515]:
dbus-update-activation-environment: setting
SSH_AUTH_SOCK=/run/user/1000/openssh_ag>
dbus-update-activation-environment: setting SSH_AGENT_LAUNCHER=openssh
Jun 21 11:18:46 work agent-launch[1513]:
SSH_AUTH_SOCK=/run/user/1000/openssh_agent; export SSH_AUTH_SOCK;
Jun 21 11:18:46 work agent-launch[1513]: echo Agent pid 1513;
We observe that the file /run/user/1000/openssh_agent is different from
/home/user/.SSH_AGENT_sshkeys. That may be a problem.
I tried to fix that temporarily with linking one to the other ("ln -s")
. Then ssh-add -L does not fail, but has no identities.
Here I am stuck. Any hints? Thank you, Bernhard
