one bug: man page for qube-dom0-update refers to yum instead of dnf.
another bug: system went to sleep / suspend when it was in the middle of downloading updates with Qubes Update command. Not good. I have to myself disable suspend in settings until it is finished.
last bug: many of my qubes are staying on 60% CPU use when they are idle. This seems to be happening when they are not running any application, so after they are launched at login and after I close the last application. I can fix it if I restart the qube or run an app from it. But this kills my battery.
First one must be for all but perhaps last two are just for me?
