on Qubes 4.3 (inline-upgraded from 4.2), I tried to decouple the screensaver from screen locking, so I can intervene (mouse move, or hitting Ctrl) before the screen actually gets locked. But I don't get it to work that way.
In "Screensaver Preferences" / "Screensaver"
- Activate screensaver when computer is idle: on
- Regard the computer as idle after: 5 minutes
In "Screensaver Preferences" / "Lock Screen":
- Enable Lock Screen: on
- LockScreen With Screensaver: on
- Lock the screen after the screensaver is active for: 15 minutes
But no matter if xfce4-screesaver activates the screensaver, or if power manager activates "blank screen", the screen always gets locked immediately.
I also tried disabling "Display power management" in Power management for both "On battery" and "Plugged in", doesn't help.
I have an Arch Linux installation on a different machine where this works as expected using xfce4-screensaver.. It also worked before on Qubes 4.2 and xscreensaver..
Unlike 4.2.4, "blank screen" screensaver results in instant power off
and impossibility to power on without blindly typing the password to
unlock first.
My solution was to:
- stop using "blank screen" screensaver
- use "Floating Xfce" instead (activated after 5 min)
- let the "Power management" do the rest (after 15 min)
thanks for your input. Now I seem to have it working, but this is all very strange. Not sure if it will still work tomorrow or next week
After any change of screensaver theme, screensaver would immediately screenlock. After changing "blank screen" interval in Power Manager, screensaver will not immediately screenlock anymore. Probably power manager just needs a nudge and any modification would do.
Weirdness still applies: setting "blank after" in Power Manager to "Never" appears to completely inhibit the screensaver. After setting "blank after" to something high like 30min, screensaver would again immediately screenlock.
Non-determinism also applies: I had it working at one point even with "blank screen" screensaver theme, but after some further experiments that stopped working (immediate screenlock again) and I could not get it back to work.
I currently use the "slideshow" screensaver theme. This gives a nice empty screen (lack of images to show?). Floating xfce mice are fun but a bit distracting, Now I don't have immediate screen locks anymore.
An observation: I can apparently get it to not immediately screenlock as long as "idle after" (screensaver) < "blank after" (power manager) < "lock screen" (screensaver)
Still needs the power manager nudge, though. If "blank after" is set to "Never" or higher than "lock screen", I get immediate screenlock, Otherwise screenlock is not immediate, but kicks in after "blank after" (power manager), overriding "lock screen" (screensaver).
This is with xfce4-screensaver-4.18.4-4.fc41 in dom0
On Arch (xfce4-screensaver 4.20.1-1), Power Manager does not even have a "blank screen" option, just "Put to sleep after" and "Switch off after". I think that is an improvement, as "blank screen" in power manager is in conflict with using screensaver.
I don't know my settings by heart (on the mobile now), but I also disliked this:
When my screensaver is activated it starts to darken the screen within 5 seconds or so, and even if I move the mouse or hit a key, the screensaver continues to blacken and lock the screen.
On other systems the actual locking (and darkening) can be aborted by providing some key or mouse activity while the screen is still fading. I think this is more user-friendly than the Qubes OS behavior.
I think I found the root cause! It seems like xss-lock is causing this, and if you kill it with “pkill xss-lock”, the problem no longer occurs. I now successfully set the screensaver to activate after 1 minute, and the system to lock for another 1 minute after that, giving me a chance to cancel the locking by moving the mouse or typing. I have Display Power Management turned off in XFCE4 Power Manager.
If “pkill xss-lock” worked, make it persistent by using an autostart override:
From what I can tell, xss-lock was used in R4.2 and earlier to allow xscreensaver and sleep events to trigger the lock screen correctly, but that seems to be redundant now because xfce4-power-manager and xfce4-screensaver handle this together already. I suspect we should probably submit a patch, but would be interested first in hearing if there are any reasons to keep xss-lock.
