I have pfSense (BSD) installed, and working fine for over 6 mos now, as my network IDPS on the external interface. Went OCD and created a complete installation guide and integration script.
It’s a bit long and detailed but it works like a charm:
opened 03:53PM - 05 Oct 21 UTC
Qubes OS's implementation of sys-net is limiting as an internet facing router. S… ince Qubes OS (Qubes) is a virtualization platform, it is reasonable to implement a more featured OS on the external interface instead.
This guide will get you an instance of OpenBSD that services the hardware Ethernet interface. You can then choose what functionality you want to install, such as a hardened router, a firewall, IDPS, etc.
Credit to notes **[1]** and comments **[2]** from @unman.
I highly recommend following these steps in the order presented. (See discussion at bottom for details.):
1. Preparations:
a. Shutdown all VMs.
b. Backup dom0, sys-net, and sys-firewall.
c. All steps can be performed in the GUI except:
-- i. Step 5, creating the openbsd-21 HVM TemplateVM, and
-- ii. Step 10, running the script in sys-firewall.
2. In the sys-firewall VM change these settings:
a. Confirm "Provides network" is set to "True".
b. Set NetVM, aka "Networking", to none.
c. Add in "Services" the following:
-- i. "clocksync" daemon.
-- ii. "qubes-update-check".
-- iii. "qubes-updates-proxy".
-- iv. "qubes-yum-proxy".
3. In the sys-net VM settings:
a. Remove all hardware devices.
b. Confirm "Provides network" is "True".
c. Set NetVM, aka "Networking", to "sys-firewall".
d. Change virtualization mode to "PVH".
e. Change the following "Services":
-- i. Remove "clock-sync".
-- ii. Add "qubes-yum-proxy".
-- iii. Add "qubes-updates-proxy".
-- iv. Add "qubes-update-check".
4. Start the sys-firewall VM.
5. Create a HVM as a class of TemplateVM **[3]** **[4]** with these settings:
a. Keeping the naming convention, my example uses the name "openbsd-21".
b. dom0 command line (note that the kernel property is set to two single tick marks, aka, "none"):
`qvm-create openbsd-21 --class TemplateVM --property virt_mode=HVM --property kernel='' --label purple`
d. Set "Start qube automatically on boot" to "False".
e. Add network hardware "Devices". (For me it's 00:19.0 Ethernet controller: Intel Corp...)
f. Confirm the kernel is set to "none".
6. Create a new HVM with class of AppVM using the openbsd-21 HVM TemplateVM in Step 5 above with these settings:
a. Name "openbsd-21-sysnet".
b. Set NetVM, aka "Networking", to "sys-firewall".
c. Set "Start qube automatically on boot" to "False".
d. Add network hardware "Devices". (For me it's 00:19.0 Ethernet controller: Intel Corp...)
7. Note the static IP assignment to "openbsd-21-sysnet" by Qubes.
a. From Qubes Manager find the IP address assigned to the "openbsd-21-sysnet" VM.
-- i. For me, it is 10.137.0.16
b. If you have any trouble with this step then try this:
-- i. Reboot Qubes OS.
-- ii. Start "openbsd-21-sysnet" VM.
-- iii. Let it run until it at least identifies the Xen virtual ethernet interface "xn0".
-- iv. Stop "openbsd-21-sysnet" VM.
8. Install OpenBSD in the "openbsd-21" HVM TemplateVM.
a. Assign interfaces. Your LAN interface to sys-firewall is going to be xn? For me, LAN is xn0 and WAN is em0.
b. Assign the static IP address from Step 7 above. For me it is 10.137.0.16 to the "xn0" interface.
c. Change root password.
d. Shutdown the "openbsd-21" TemplateVM.
9. Now start "openbsd-21-sysnet" and confirm the above settings copied from the parent "openbsd-21" TemplateVM:
a. Interface assignments. (Again, my LAN is xn0 and WAN is em0).
b. Interfaces' IP addresses.
-- i. For me, WAN is set by DHCP and the LAN static is 10.137.0.16/24.
-- ii. Note that this LAN static IP address was set by Qubes when openbsd-21-sysnet was instantiated in Step 7.
c. For some reason I had to repeat the OpenBSD configuration in "openbsd-21" TemplateVM twice to make the root password change.
10. In "sys-firewall", create a script to route traffic to "openbsd-21-sysnet":
a. The script needs to set the gateway, allow other VMs access, and identify the DNS server. For me it is like this:
#!/usr/bin/sh
# Logging Function
sysidps_log () { echo -e "$(date "+%F %T")" "$1" | tee -a >&1 "$log_file"; }
log_msg_fail="Timed out waiting on gateway."
log_msg_chk="Checking gateway for ICMP echo reply..."
log_msg_up="Gateway replying to ping requests!"
log_msg_rte="Gateway set as the default route."
log_msg_gw="Virtual ifaces routing through gateway."
log_msg_ns="Name servers added to routing table."
log_file="/var/log/qubes/sys-idps"
# Hard code static IP addresses. You'll need at least one name server.
gw_ip=10.137.0.14
#ns1_ip=10.137.252.1
ns2_ip=10.137.1.1
# Wait for gateway to come up.
# Maximum wait time is 8 hrs before exits with failure.
# Your Gateway Must Reply To (Does Not Block) ICMP Echo Requests!
up_reply="0% packet loss,"
ping_chk="false"
declare -i time_out=0
time_base=$(date "+%s")
while [ "$ping_chk" != "$up_reply" ]; do
if [ $time_out -lt 300 ] ; then sleep 1 ;
elif [ $time_out -lt 600 ] ; then sleep 3 ;
elif [ $time_out -lt 1200 ] ; then sleep 5 ;
elif [ $time_out -lt 1800 ] ; then sleep 8 ;
elif [ $time_out -lt 3600 ] ; then sleep 15 ;
elif [ $time_out -lt 14400 ] ; then sleep 30 ;
elif [ $time_out -lt 28800 ] ; then sleep 60 ;
else sysidps_log "$log_msg_fail" && exit 1 ;
fi;
sysidps_log "$log_msg_chk";
ping_chk=$(ping -c 1 -r $gw_ip | grep "0% packet loss" | cut -d ' ' -f 6-8);
time_out=$(date "+%s")-$time_base;
done
sysidps_log "$log_msg_up"
# Set gateway as default route.
# Running "ip route add" first makes discovering gw_vif easy.
ip route add default via $gw_ip
gw_vif=$(ip route show default | cut -d ' ' -f 5)
sysidps_log "$log_msg_rte"
# Add all VMs vif routing to/from gateway.
iptables --insert FORWARD --in-interface vif+ --out-interface $gw_vif --jump ACCEPT
iptables -t raw --insert PREROUTING --in-interface $gw_vif --jump ACCEPT
sysidps_log "$log_msg_gw"
# Add routing to name server resolution. Call Qubes name server script.
rm -f /etc/resolv.conf
if [ "X$ns1_ip" != "X" ] ; then echo "nameserver $ns1_ip" >> /etc/resolv.conf ; fi
if [ "X$ns2_ip" != "X" ] ; then echo "nameserver $ns2_ip" >> /etc/resolv.conf ; fi
/usr/lib/qubes/qubes-setup-dnat-to-ns
sysidps_log "$log_msg_ns"
exit 0
11. You could make this a background process in /rw/config/rc.local. If so, then set openbsd-21-sysnet to "Start qube automatically at boot". I sometimes tail /var/log/qubes/sys-idps.
a. For me, it looks like this:
# Poll for and then set up system gateway:
/rw/config/qubes-openbsd-sysnet-script &
12. Set the "fedora-32-dvm" "NetVM" to "sys-net".
a. This works around Qubes' 10.138.0.0/24 networking on disposable VMs.
b. Repeat for all your DisposableVMs.
c. Note: In Step 3 the "sys-net" Networking was set to "sys-firewall".
13. Thoughts and concerns:
a. You have to manually manage a few of things:
-- i. Match the LAN static IP address for "openbsd-21-sysnet" to what Qubes auto-assigns; conceivably, your actions could inadvertently change it.
-- ii. Setting your static IP values used in the script.
b. This requires editing the "openbsd-21" TemplateVM to make changes that persist in "openbsd-21-sysnet".
-- i. My OpenBSD instance in the "openbsd-21" didn't save my root account changes until the third try. Just triple check that all your changes were saved if your "openbsd-21-sysnet" AppVM has issues.
c. Several steps given above are only cautionary, or good practice.
d. A couple of things that Qubes hard codes:
-- i. TemplateVM updates to proxy via "sys-net". So I had to enable some services on "sys-net".
-- ii. Disposable templates route through "sys-net". So, "sys-net" here forwards to "sys-firewall".
e. During initial testing occasionally the hypervisor backend wouldn't release the PCI ethernet controller. Hence, Step 7.b. I haven't has any trouble since.
f. This is a working integration guide and shell script. Edits are welcomed.
[1] https://github.com/unman/notes/blob/master/openBSD_as_netvm
[2] https://groups.google.com/g/qubes-users/c/MpXLhz5COvM/m/smHA6a0VBgAJ
[3] https://www.qubes-os.org/doc/standalones-and-hvms/
[4] https://dev.qubes-os.org/projects/core-admin-client/en/latest/manpages/qvm-create.html
Demi
May 17, 2022, 5:35pm
2
I managed to get an OpenBSD template sort of working a while back. I
was able to get networking and storage to work, and X11 worked via
emulated VGA, but I ultimately gave up because of some clashes on the
OpenBSD mailing lists. A proper integration would require substantial
additions to the OpenBSD kernel:
- - nullfs (BSD version of bind mounts) for /home and /usr/local. The
workaround (a loopback NFS mount) is not something I would be okay
with for production use.
- - Hardened xnf(4) (netfront) and xbf(4) (blkfront) drivers. The current
drivers are not safe in the presence of malicious backends.
- - Userspace access to Xen event channels and grant tables, so that
libvchan and gui-agent can work.
Additionally, a Xen-aware bootloader would be needed if booting other
than in HVM mode is desired.
Sincerely,
Demi Marie Obenour (she/her/hers)
Invisible Things Lab
Yeah, a more integrated BSD OS would be nice. Something like Windows tools. The only gui I’d be interested in though is macos.
In this case, I’m just running the cli and using the webapp for management. Sure it’s a HVM and is more isolated and more resource hungry. Yet it’s a lot like my stand alone pfSense box. It just works. And over the months I’ve gone back to my integration guide/script and refined it.
Keep in mind that I answered the OP’s question for the use case where “any” means a HVM with a CLI and using a webapp for “gui” management. The integration guide/script is optional for people wanting to replicate my implementation of pfSense/OPNsense.
BTW, could you expound a little on your concern for xnf(4) (netfront) and xbf(4) (blkfront) drivers? Or point me to a reference? I wish to better understand your concern for threat vectors.
Demi
June 11, 2022, 12:12am
4
Right now, the OpenBSD netfront and netback drivers are not hardened
against malicious backends, so they can be attacked by malicious
backends.
Sincerely,
