Update: Everything seems to work now! The system suspends and recovers correctly. The cursor lag has disappeared. Another problem of slow, choppy video and no audio has also disappeared. The system has been working correctly for about 2 months now. I suppose one of the updates resolved the problems. I have not tried hibernate yet as I don’t use it. I will probably try it at some time and will report. In the future I will install the latest version and use both drives on this laptop. Many thanks to the Qubes people for a great system! I will donate!
layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
LENOVO
model: |
20RES6DF07
bios: |
R16ET42W (1.28 )
cpu: |
Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Comet Lake-U v1 4c Host Bridge/DRAM Controller [8086:9b61] (rev 0c)
chipset-short: |
FIXME
gpu: |
Intel Corporation CometLake-U GT2 [UHD Graphics] [8086:9b41] (rev 02) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Comet Lake PCH-LP CNVi WiFi [8086:02f0]
memory: |
32448
scsi: |
SSDPR-CX400-01T- Rev: 8A0
usb: |
1
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.2.4
xen: |
4.17.5
kernel: |
6.12.35-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
To make Qubes OS run on this laptop, I had to make sure that dom0’s Linux commandline has the options i915.enable_dc=0 ahci.mobile_lpm_policy=1 set, otherwise GPU hangs were present, especially when running on battery, without line power.
Other than that, everything seems to work out of the box. The system does resume correctly after suspend.
(attachments)
Qubes-HCL-LENOVO-20RES6DF07-20250731-082843.yml (869 Bytes)
