Dear Qubes community,
my qubes r4.0 legacy installation does not boot any more. Very abruptly, because I hadn't done any updates or changed anything in dom0 lately. There was also no power loss or anything. And I didn't move any larger files the last time I successfully used Qubes.
Whenever I try to boot, this happens: the boot loader appears normally and then I can enter the hard drive password as usual. After entering, the progress bar moves very slowly and the status LED on the PC suggests that the processor has nothing to work with. After a while the following appears:
[ 215.211434] dracut-initqueue[396]: dracut-initqueue timeout - starting timeout scripts
[ 215.314434] dracut-initqueue[396]: Warning: could not boot.
[ 215.451434] dracut-initqueue[396]: Warning: /dev/qubes_dom0/swap does not exist
Starting Dracut Emergency Shell...
Generating "/run/initramfs/rdsosreport.txt"
Entering emergency mode.
After that lines it asks if I want to save the error report to a USB stick or to /boot.
I also tried what happens if I enter a wrong password at startup: Then it prompts to enter it again - so the system still knows which is the correct password. I checked the bios settings, but nothing changed there.
I have not tried what happens if I
- remove the hardware battery,
- select any option in the Advanced Options for Qubes in the boot loader, e.g. booting from another kernel,
- clone the SATA SSD to another SATA SSD and try to boot from that one,
- remove the PCIe card with the NVMe SSD from the computer, on which I recently tried unsuccessfully to install qubes (maybe the SATA installation of qubes is bothered by this?).
I have never had the problem that qubes does not start. Also the initial installation had worked immediately. All hardware dependencies that qubes has are fulfilled.
The above dracut-initqueue error text I knew so far only from the occasion where I had entered the password 2 times wrong. Then it had been reported that /dev/mapper/qubes_dom0-root as well as /dev/qubes_dom0/root and /dev/qubes_dom0/swap would not exist.
But now the system just complains that /dev/qubes_dom0/swap would not exist. So maybe not a big error?
Could someone give me a tip on how to get the system working again or backup the important AppVMs to be able to move them to a new installation?
All the best and thank you in advance
Michael Singer
