Dear Qubes Community,
I am trying to install Qubes 4.2. in vain, not because the hardware is incompatible, but because of Salt problems. I verified the downloaded ISO according to the instructions, burned the ISO with various programs on a USB stick, among others with the DD command:
dd if="./Qubes-R4.2.1-x86_64.iso" of="/dev/sda" status="progress" conv="fsync"
I have checked the result and it shows that the hash sum of the USB stick under /dev/sda is the same as the downloaded file:
sudo dd if=/dev/sda bs=1M count=$(stat -c %s /home/user/QubesIncoming/XXX/Qubes-R4.2.1-x86_64.iso) iflag=count_bytes | sha256sum
a942911a3a4975831324a064f70b34c6965c4e9f6c95afbc531f04d55f947376
When I start the computer with the USB stick and test the medium, the following appears first:
Fragment sums: 2695f8d1(...)
supported iso: no
Then, when the test has run 100 percent, the following appears:
[FAILED]
If I install anyway, I have to cancel the automatic creation of sys-net, sys-usb and personal AppVMs, because otherwise I get an installation error because the installer does not set the PCI devices to disable strict reset. At the end of the setup it still says:
"initial config failed", see /var/log/salt/minion
The log there says:
Specified ext_pillar interface qvm_prefs unavailable
And when I try to update dom0, it fails. The reason is noted in the same log file:
Unable to detect release version
Cannot prepare internal mirror list: SSL peer certificate or SSH remote key was not OK for https://mirrors.fedora(...)
Everything otherwise works according to the HCL report, including Suspend, Ethernet, USB, Speaker. Strange thing was that no default-mgmt-dvm seemed to be present and was not started during update attempts.
I have already tried the installation with 4.2.0 and 4.2.1, with standard kernel and with the latest kernel.
How could I solve the problem?
Thank you,
Michael Singer
