Hello,
i installed Qubes 4.1 beta on my 11th gen Intel Dell Latitude 5520.
When i try to start sys-net i get “Unable to reset PCI device […]: no FLR, PM reset or bus reset available”
I cannot use qvm-pci to set permissive mode, becau qvm-pci gives me an error about no permission for pci devices, even when run as root.
Also the Devices tab in qubes-manager on all VMs is greyed out.
Is there anything which i can check?
Best regards
Mario
'Mario Geckler' via qubes-users:
Hello,
When i try to start sys-net i get "Unable to reset PCI device […]: no FLR, PM reset or bus reset available"
You were close with permissive mode. Try setting the NIC in sys-net's Qube Settings/Devices to Not require strict mode reset. It's a bit less secure, but ought to at least work.
