[qubes-users] [Q4.2] [default DVM]
Hi, could someone kindly explain me how to change the template of the
default dvm (or similarly, add a second one). I tried several
explanations online, but none worked. I prefer to understand the
procedure via dom0 terminal commands, but if you have a "click you
through" solution, I take it as well. Cheers, Bernhard
you can use qvm-prefs [vm] template [new template].
BR
David
Hi
Say that I have a template called debian-12 and I run
 qvm\-prefs denian\-12 template debian\-12\-dvm
That gives
usage: qvm\-prefs \[\-\-verbose\] \[\-\-quiet\] \[\-\-help\] \[\-\-help\-properties\]
[--hide-default] [--get] [--set]
 \[\-\-default\] VMNAME \[PROPERTY\] \[VALUE\]
 qvm\-prefs: error: no such property: 'template'
That is where I was stuck with the manual .... best, Bernhard
It's probably the other way around:
qvm-prefs debian-12-dvm template debian-12
alright, this works (after shutting down all instances of the dvm)
qvm-prefs default-dvm template debian-12
thank you. Bernhard
