Hi!
Upgrading the whonix-gw template resulted in an unexpected error:
Updating Qubes App Menus and advertising features...
Processing triggers for desktop-file-utils (0.23-4) ...
Processing triggers for tex-common (6.16) ...
Running updmap-sys. This may take some time... done.
Running mktexlsr /var/lib/texmf ... done.
Building format(s) --all.
W: APT had planned for dpkg to do more than it reported back (570 vs 575).
Affected packages: texlive-latex-base:amd64
+ true 'INFO: Install pre release upgrade of dependency packages (2/2)...'
+ apt-get-noninteractive --yes --no-install-recommends install sdwdate
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
sdwdate : Depends: helper-scripts but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
+ true 'ERROR: An error was encountered during download of dependency packages. Recommendation:
Fix network connection and retry.'
+ exit 1
I'm kind of clueless what to do. The recommended fix did not work:
ser@host:~$ sudo apt-get-noninteractive --yes --no-install-recommends install sdwdate
Ideas?
Regards,
Ulrich
