[qubes-users] No NHLT in VMs -> no microphone?
My (new) laptop’s built-in microphone works in dom0 but not in my audio-VM (i use audio-VMs with other Qubes computers and it was always fine).
dmesg complains about “NHLT table not found”, and in deed: dom0 has /sys/firmware/acpi/tables/NHLT and the VMs don’t (neither using fedora nor debian). Is that the reason, and if so: how to fix it?
Installed newer versions of alsa-sof-firmware / firmware-sof-signed but no change.
dom0 recognizes the sound card (intel hda ALC236) with all features/controls, but the audio-VM sees only a limited set and mic is dead (speaker works).
Qubes OS R4.3 on an HP Elitebook 650 G11, Intel Core Ultra 5 135U, Meteor Lake-P, kernel 6.18.4-1
Just a wild guess: could the alsa-ucm package be missing?
alsa-ucm-conf is installed. I really think it is an ACPI problem, the VMs just don’t have the capabilities of dom0.
Connecting the audio controller (Multimedia audio controller [0401]: Intel Corporation Meteor Lake-P HD Audio Controller [8086:7e28] (rev 20)) to the audio VM says:
[ 3.335463] sof-audio-pci-intel-mtl 0000:00:09.0: NHLT table not found[ 3.335661] sof-audio-pci-intel-mtl 0000:00:09.0: DMICs detected in NHLT tables: 0
While dom0 says:
[ 37.489569] sof-audio-pci-intel-mtl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 37.544083] sof-audio-pci-intel-mtl 0000:00:1f.3: DMICs detected in NHLT tables: 2
dom0 recognizes and uses the controller correctly/fully, while a VM only does a crippled mode with some basic intel-hda functionality. Both have the same kernel, sof-drivers, etc. but the VM does not have the NHLT table. The internal microphone does not work with the VM.
In case one has the same problem: I did not solve it, the on-board sound card still does not work properly in a VM.
My workaround: i leave the pci soundcard in dom0, and have all other soundcards (USB, bluetooth) in the audio-VM.
This, combined with two volume tray elements (one for dom0 and one for audio-VM) and the commands
user@dom0:~$ qubes-prefs default-audiovm sys-usb
user@dom0:~$ qubes-prefs default-audiovm dom0
enables me to switch between all audio cards that i have.
