Good Morning again,
I got the OSINT VM about 95% setup. Thank you all for your help on it. I
ran into problems during the install of a few recommended tools in the Mike
Bazzell OSINT manual. These programs are as follows: EyeWitness,
theHarvester, pipenv, and kazam.
Kazam seems like something I don't actually need but I'd still like all
tools set up. Below is the terminal text I saved in a "todo" txt file. Any
help understanding the error messages and what I need to do to resolve them
would be appreciated. I recognize everyone on here is quite busy but this
n00b would definitely appreciate the help. Thank you.
You have not said where, or how, you are trying to install these - in Template,
Standalone, or template based qube.
1. Fix Eyewitness
# EyeWitness Setup #
[Error]: \S is not supported by this setup script.
Clear - look in the setup script. You are using a parameter "\S" that is
not supported.
[user@OSINT-Template setup]$
2. Fix theHarvester
3. Fix pipenv
You have repeated error 502 - this is "Bad Gateway"- change your routing
to these sites.
You do not have right python installed - the requirement is specific -
=2.7, but less than 3.0.
Install and configure your python(s) as necessary.
4. Fix kazam
[user@OSINT-Template kazam-1.4.4]$ sudo python3 setup.py install
File "setup.py", line 8, in <module>
from DistUtilsExtra.command import *
ModuleNotFoundError: No module named 'DistUtilsExtra'
You need to install DistUtilsExtra - in Debian based qubes you should
install python-distutils-extra or python3-distutils-extra , depending on
your python version.
