I tried to upgrade my Qubes OS system from 4.1.2 to 4.2.0 using the “qubes-dist-upgrade” script.
The upgrade failed - and - now the system is in a ‘weird’ state.
None of the Fedora- or Debian-based VM have ‘external / public’ network access anymore.
The ‘anon-whonix’ VM however still does have ‘external / public’ network access - and - the update of templates through the Qubes Updater is also still working …
I did perform a backup a backup of all VMs before starting the script - but - would like to skip a new install if possible ! - Any advice / ideas ?
"qubes-dist-upgrade" script.
The upgrade failed - and - now the system is in a 'weird' state.
None of the Fedora- or Debian-based VM have 'external / public'
The 'anon-whonix' VM however still does have 'external / public'
Updater is also still working ...
OK, I am not an expert on THIS question. Some general remarks: the
network card seems to work, right? So you need to check where the chain
breaks.
- go to sys-net (open terminal via widget) type ping 8.8.8.8 and see if
you come out
- go to sys-firewall (terminal via widget) and do the same.
if these two work, and an app-vm has no network, its config got lost.
Look at network settings of the corresponding appVM. It should be
sys-firewall in std setting, apart anon-whonix, of corse which uses
sys-whonix.
breaks.
you come out
Working.
Working as well.
sys-whonix.
Not working. - I changed the settings from “default (sys-firewall) (current)” to “sys-firewall” in one App-VM …
An additional / new info is, that an update check for ‘dom0’ does no longer work !
I did not explicitely try that before …
Does it make sense to try to just restore ‘dom0’ as a start ?
breaks.
you come out
Working.
Working as well.
sys-whonix.
Any feedback - or - any other ideas what I could try ?
breaks.
you come out
Working.
Working as well.
sys-whonix.
all updates go via tor network (sys-whonix) by default. You could click on the blue qube widget → sys-wonix → run terminal and see if sys-whonix has network. But I guess not. Here is why:
It took much longer due to private reasons - but - I can report that I was able to fully recover from the backups !
What I did different than suggested was that I started with a clean re-install of Qubes OS 4.1 …
