hi ervery,
when I try to run qvm in dom0 terminal, command is not find, and I try to creat new file in the /etc/NetworkManager/conf.d/ , access also denied. I wonder is my user do not have the authority?
There are *many* qvm- commands in dom0 - type qvm and then TAB to see
them.
The one you will use most often is qvm-run
To edit config files you will want to use `sudo` or`sudo su -` to get root.
