An attempt to shutdown sys-firewall in Qube Manager receive a warning about running processes in the qube; similarly on command line qvm-shutdown sys-firewall fails with an error. Is it possible to designate an appVM to behave similarly so it won’t get shutdown accidentally?
Boryeu Mao:
An attempt to shutdown `sys-firewall` in `Qube Manager` receive a warning
`qvm-shutdown sys-firewall` fails with an error. Is it possible to
designate an appVM to behave similarly so it won't get shutdown
accidentally?
Not as a user-facing feature AFAIK. But you could use the qubes.ext
Python entry point
to add another "domain-pre-shutdown" event handler like this one
(yours could e.g. check if the VM has a certain tag):
Rusty
Rusty Bird:
Boryeu Mao:
> accidentally?Not as a user-facing feature AFAIK. But you could use the qubes.ext
Python entry pointqubes-core-admin/qubes/ext/__init__.py at v4.2.21 · QubesOS/qubes-core-admin · GitHub
(yours could e.g. check if the VM has a certain tag):qubes-core-admin/qubes/ext/audio.py at v4.2.21 · QubesOS/qubes-core-admin · GitHub
Sorry, that second link should have been:
Rusty
Thank you very much for the help. Time for a crash course on qubes-core-admin.
