I want to reinstall Qubes 4.1, but I cannot select any templates in the installer.
Qubes 4.0 and 4.1 were already running successfully on my device and Qubes 4.0 can still be installed successfully.
In the install menu, Fedora, Debian and Whonix are missing from the software selection, which is why all templates and app vm's are missing after the installation and only dom0 remains.
On Github an issue was reported, but closed again ( Installation: Anaconda: Not asking for VNC because we don't have a network #7490 ). However, there is no solution.
I've seen this before when the USB drive gets only partially created. Make sure it's large enough for the bigger 4.1 image, and if you didn't use DD to create it, try that route.
A common pitfall when creating the stick with Linux is that even after DD had finished, Linux stil ldoes writeback the dirty buffers.
If you have a slower stick without an LED, you are heading fro trouble.
Maybe try a sync before ejecting the stick.
