img 2 - text appears in dotted characters of no language and doesn’t make sense (it’s not even Braille). Also, text cursor (underscore) appears oddly twice.
img 3 - more of this text… At the end it allows keyboard input but I can’t know what input to enter. If pressing “Enter” key, it reshows the last line.
Between each image there’s an empty black screen for about half a second.
** Couldn’t attache images\videos
It than accepts input, but I can’t know what input to enter.
I tried numerous versions, almost all of them; some did better, some less. Version 4.0 looked better than all the others and this is what is shown in the video.
Other versions asked me first if I want to “test and install”, “install” and so on, the normal menu.
I tried to look in the documentation and in forums. In addition, I’ve asked in some forums – none of them helped.
I’m new to Qubes so it’s possible my answer is out there but I didn’t notice.
Any tip, lead or advice would be much appreciated.
Actually you won't have much fun with only 8 GB RAM; 16 is probably OK, and 32 or more is nice. Remember that at least four operating systems have to run (Dom0, net, firewall, app).
Is your installation medium fine? Maybe, you should check if there is no difference between the image on the installation medium and the original ISO image file. Do you use Linux? If yes, see
(Do not forget to replace `/dev/sda` with the actual installation medium and use the correct size and ISO image.)
If you need more help on this, don't hesitate to ask!
Regarding the installation media - I installed it according the installation instructions described on the website (with Rufus) and I use windows 11 to make the installation media.
According to what I understand, the bash command in the link compares the size of both the media and the file downloaded. I compared with the the “properties” window of the “File Explorer” and the media has almost 1 MB more than the ISO file I downloaded. Is it right?
Regarding the low RAM - I know it’s not ideal but it’s for educational purposes about the OS itself, nothing too demanding, so I don’t expect it to run smoothly and I won’t be using many softwares.
With this little RAM, should I be able to install it and use it at all, or will it probably not going to work?
Also, assuming I’ll manage to install it, how bad will it behave? Should I give up on trying to install Qubes OS on this hardware at all?
Okay.
"properties" window of the "File Explorer" and the media has almost 1 MB
It is probably right that the "properties" window of the "File Explorer" shows a size (partition size?) that is a little bit bigger than the ISO file. At least, it makes sense.
However, the bash command does not compare the sizes. It compares the relevant *content* on your installation medium with that of the ISO file. If they are different, a message like
Binary files - and Qubes-R4.1.0-x86_64.iso differ
will show up when the command terminates, else not.
You may wonder why the content could be different. I don't know the answer but my experience is that sometimes there are faulty spots on a USB flash drive. This could lead to everything: Hanging installation, graphical glitches or even an unbootable device (in this case, the device is the mentioned USB flash drive).
Do you have an installed Linux anywhere (or a live Linux)? You could use that in order to execute the appropriate command. Else: Does anybody know how to compare the installation medium and the ISO file under Windows 11?
You could also just rewrite your installation medium with Rufus again and try installation again.
