Hi!
As announced, here are more details of the problem I saw:
First I was surprised that some packages will be downgraded:
Downgrading:
device-mapper x86_64 1.02.199-4.fc41 qubes-dom0-cached 133 k
device-mapper-event x86_64 1.02.199-4.fc41 qubes-dom0-cached 31 k
device-mapper-event-libs x86_64 1.02.199-4.fc41 qubes-dom0-cached 28 k
device-mapper-libs x86_64 1.02.199-4.fc41 qubes-dom0-cached 174 k
lvm2 x86_64 2.03.25-4.fc41 qubes-dom0-cached 1.5 M
lvm2-libs x86_64 2.03.25-4.fc41 qubes-dom0-cached 996 k
python3-kickstart noarch 3.58-3.fc41 qubes-dom0-cached 492 k
qubes-desktop-linux-menu noarch 1.2.10-1.fc41 qubes-dom0-cached 120 k
Then there were some strange errors before reboot:
Running scriptlet: qubes-mgmt-salt-dom0-qvm-4.3.5-1.fc41.noarch 1264/2592
Invalid chars in property name: {'=', ' '}
Running scriptlet: qubes-mgmt-salt-dom0-virtual-machines-4.3.13-1.fc41.noarch 1265/2592
Upgrading : qubes-mgmt-salt-dom0-virtual-machines-4.3.13-1.fc41.noarch 1265/2592
Invalid chars in property name: {' ', '='}
During boot I saw these messages (Lenovo ThinkPad P16 Gen 2, i9-13980HX with Nvidia Ada 2000):
Dec 22 17:17:46 dom0 kernel: installing Xen timer for CPU 22
Dec 22 17:17:46 dom0 kernel: installing Xen timer for CPU 23
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 2: APIC ID mismatch. CPUID: 0x0002 APIC: 0x0008
Dec 22 17:17:46 dom0 kernel: cpu 2 spinlock event irq 201
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 4: APIC ID mismatch. CPUID: 0x0004 APIC: 0x0010
Dec 22 17:17:46 dom0 kernel: cpu 4 spinlock event irq 202
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 6: APIC ID mismatch. CPUID: 0x0006 APIC: 0x0018
Dec 22 17:17:46 dom0 kernel: cpu 6 spinlock event irq 203
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 8: APIC ID mismatch. CPUID: 0x0008 APIC: 0x0020
Dec 22 17:17:46 dom0 kernel: cpu 8 spinlock event irq 204
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 10: APIC ID mismatch. CPUID: 0x000a APIC: 0x0028
Dec 22 17:17:46 dom0 kernel: cpu 10 spinlock event irq 205
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 12: APIC ID mismatch. CPUID: 0x000c APIC: 0x0030
Dec 22 17:17:46 dom0 kernel: cpu 12 spinlock event irq 206
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 14: APIC ID mismatch. CPUID: 0x000e APIC: 0x0038
Dec 22 17:17:46 dom0 kernel: cpu 14 spinlock event irq 207
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 16: APIC ID mismatch. CPUID: 0x0010 APIC: 0x0040
Dec 22 17:17:46 dom0 kernel: cpu 16 spinlock event irq 208
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 17: APIC ID mismatch. CPUID: 0x0011 APIC: 0x0042
Dec 22 17:17:46 dom0 kernel: cpu 17 spinlock event irq 209
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 18: APIC ID mismatch. CPUID: 0x0012 APIC: 0x0044
Dec 22 17:17:46 dom0 kernel: cpu 18 spinlock event irq 210
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 19: APIC ID mismatch. CPUID: 0x0013 APIC: 0x0046
Dec 22 17:17:46 dom0 kernel: cpu 19 spinlock event irq 211
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 20: APIC ID mismatch. CPUID: 0x0014 APIC: 0x0048
Dec 22 17:17:46 dom0 kernel: cpu 20 spinlock event irq 212
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 21: APIC ID mismatch. CPUID: 0x0015 APIC: 0x004a
Dec 22 17:17:46 dom0 kernel: cpu 21 spinlock event irq 213
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 22: APIC ID mismatch. CPUID: 0x0016 APIC: 0x004c
Dec 22 17:17:46 dom0 kernel: cpu 22 spinlock event irq 214
Dec 22 17:17:46 dom0 kernel: [Firmware Bug]: CPU 23: APIC ID mismatch. CPUID: 0x0017 APIC: 0x004e
Dec 22 17:17:46 dom0 kernel: cpu 23 spinlock event irq 215
Dec 22 17:17:46 dom0 kernel: installing Xen timer for CPU 1
Dec 22 17:17:46 dom0 kernel: installing Xen timer for CPU 3
Dec 22 17:17:46 dom0 kernel: installing Xen timer for CPU 5
(some systemd warning about the LUKS device not being an absolute path)
Dec 22 17:17:47 dom0 kernel: pci 10000:e0:1d.4: bridge window [mem 0xae100000-0xae1fffff]
Dec 22 17:17:47 dom0 kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT D
Dec 22 17:17:47 dom0 kernel: pcieport 10000:e0:06.0: PCI INT D: no GSI
Dec 22 17:17:47 dom0 kernel: pcieport 10000:e0:06.0: PME: Signaling with IRQ 297
Dec 22 17:17:47 dom0 kernel: pcieport 10000:e0:06.0: AER: enabled with IRQ 297
Dec 22 17:17:47 dom0 kernel: pcieport 10000:e0:1d.4: can't derive routing for PCI INT A
Dec 22 17:17:47 dom0 kernel: pcieport 10000:e0:1d.4: PCI INT A: no GSI
Dec 22 17:17:47 dom0 kernel: pcieport 10000:e0:1d.4: PME: Signaling with IRQ 298
Dec 22 17:17:47 dom0 kernel: pcieport 10000:e0:1d.4: AER: enabled with IRQ 298
Dec 22 17:17:47 dom0 kernel: vmd 0000:00:0e.0: Bound to PCI domain 10000
Dec 22 17:17:48 dom0 kernel: usb 1-4: new high-speed USB device number 4 using xhci_hcd
Dec 22 17:17:48 dom0 kernel: tmpfs: Unsupported parameter 'huge'
Dec 22 17:17:48 dom0 kernel: i915 0000:00:02.0: [drm] Transparent Hugepage support is recommended for optimal performance on this platform!
Dec 22 17:17:48 dom0 kernel: pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
Dec 22 17:17:48 dom0 kernel: VGA switcheroo: detected Optimus DSM method \_SB_.PC00.PEG1.PEGP handle
Dec 22 17:17:48 dom0 kernel: nouveau: detected PR support, will not use DSM
Dec 22 17:17:48 dom0 kernel: nouveau 0000:01:00.0: enabling device (0000 -> 0003)
Dec 22 17:17:48 dom0 kernel: xen: registering gsi 16 triggering 0 polarity 1
Dec 22 17:17:48 dom0 kernel: Already setup the GSI :16
Dec 22 17:17:48 dom0 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 22 17:17:48 dom0 kernel: sd 0:0:0:0: [sda] Spinning up disk...
Dec 22 17:17:48 dom0 kernel: nouveau 0000:01:00.0: NVIDIA AD107 (197000a1)
Dec 22 17:17:48 dom0 kernel: nouveau 0000:01:00.0: gsp ctor failed: -2
Dec 22 17:17:48 dom0 kernel: nouveau 0000:01:00.0: probe with driver nouveau failed with error -2
## why does Dom0 try to set up WiFi?
Dec 22 17:18:09 dom0 kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
Dec 22 17:18:09 dom0 kernel: cfg80211: failed to load regulatory.db
Dec 22 17:18:09 dom0 kernel: i2c i2c-11: Successfully instantiated SPD at 0x53
Dec 22 17:18:09 dom0 kernel: input: PC Speaker as /devices/platform/pcspkr/input/input16
Dec 22 17:18:09 dom0 kernel: Intel(R) Wireless WiFi driver for Linux
