I was halfway through setting my updateProxy file to go off of a sys-vpn instead of sys-whonix. However I can't remember how it was supposed to be initially. Could someone show me a default one or otherwise tell me how to adjust this one? Thank you
$type:TemplateVM $default allow,target=sys-whonix
#target formerly set to sys-vpn
## Note that policy parsing stops at the first match,
## so adding anything below "$anyvm $anyvm action" line will have no effect
## Please use a single # to start your custom comments
# Upgrade all TemplateVMs through sys-whonix (formerly sys-whonix)
# Upgrade Whonix TemplateVMs through sys-whonix (formerly sys-whonix)
$tag:whonix-updatevm $default allow,target=sys-whonix
# Deny Whonix TemplateVMs using UpdatesProxy of any other VM.
$tag:whonix-updatevm $anyvm deny
# Default rule for all TemplateVMs - direct the connection to sys-net
$type:TemplateVM $default allow,target=sys-net
$anyvm $anyvm deny
