Yesterday I filed an issue regarding hardware support for my HPZ800 and Nehalem era cpu’s I was wondering how to build a custom qubes image/iso where the following xenpatch is included ?
You should take my words with a grain of salt since I’m doing this the first time around. But anyhow.
Go to Qubes ISO Building | Qubes OS and make sure you have a Fedora VM to download everything to, and plenty of space.
Download a builder.conf file from qubes-release-configs/qubes-os-iso-full-online.conf at master · QubesOS/qubes-release-configs · GitHub (or 4.1 if that’s the version you are building)
In that file, add vmm-xen under COMPONENTS
run
make remount
make install-deps
make get-sources
Now, go into qubes-src/vmm-xen and add you patch as a file.
Enter xen.spec.in and add your patch-file under upstreamable, you’ll notice the pattern.
Go back to qubes-builder and run make vmm-xen, and the rest of the entries in $COMPONENTS in builder.conf.
( At this point you have rpm-files inside chroot-* in qubes-builder that you actually could install in dom0 instead of building a full ISO. )
run
make iso
please note that it will take a while.
