layout:
'hcl'
type:
'Desktop'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
Micro-Star International Co., Ltd.
model: |
MS-7E07
bios: |
M.70
cpu: |
Intel(R) Core(TM) i9-14900K
cpu-short: |
FIXME
chipset: |
Intel Corporation Raptor Lake-S Host Bridge/DRAM Controller [8086:a700] (rev 01)
chipset-short: |
FIXME
gpu: |
Intel Corporation Raptor Lake-S GT1 [UHD Graphics 770] [8086:a780] (rev 04) (prog-if 00 [VGA controller])
NVIDIA Corporation GA102 [GeForce RTX 3090] [10de:2204] (rev a1) (prog-if 00 [VGA controller])
3975]
3975]
gpu-short: |
FIXME
network: |
Qualcomm Technologies, Inc WCN785x Wi-Fi 7(802.11be) 320MHz 2x2 [FastConnect 7800] [17cb:1107] (rev 01)
e0f7]
Intel Corporation Ethernet Controller I225-V [8086:15f3] (rev 03)
memory: |
130841
scsi: |
nvme: |
S6B0NU0W806712L Samsung SSD 980 PRO 2TB 5B2QGXA7
usb: |
1
certified:
'no'
versions:
- works:
'FIXME:yes'
qubes: |
R4.3.2
xen: |
4.19.6
kernel: |
6.18.55-1
remark: |
Could not make WiFi work. I was able to use WiFi on 4.2, but I don't remember how I did it, and couldn't make it work on 4.3. Ethernet works out of box. I set RAM to 4800 MHz from auto 4000 MHz in BIOS and it works fine, didn't try higher. The Nvidia GPU installed on this system for LLM purposes on separate VM with pci pass through, and is not for display. In order to use monitor, I changed settings in BIOS so display goes to motherboard outputs and integrated graphic card taking care of it. I used this system with PCI AMD gpu before for 3 monitor setup and it was working with no issues. Sleep/suspend not tested (I never use it). Audio jacks are showing up as USB device. I'm having hard time to make audio work for all VMs globally, but attaching it individually to specific VM and running pavucontrol from terminal works. Other than that, global audio goes to my monitor output via HDMI. Global audio mixer sees only HDMI output and not motherboard audio jacks. I'm sure
this is fixable, I just exhausted my time to deal with it and using the monitors audio jack instead.
credit: |
BooBoo
link: |
FIXLINK
