> The two big issues in this report (aside for the need to modify the
> config in
> the install media, which is not obviously transposable to 4.1
> snapshots) are
> the lack of detection of TPM and SLAT. Will be happy to help with
> these.
Another issue is that the default 5.4 kernel does not support VFIO on
this hardware.
Is it useful to add this information to the HCL entry itself ?
So I installed kernel-latest, and that one just fails
to boot: I successively get:
- Xen startup logs
- some Linux services starting, with "Failed to start Setup virtual
console" as first line of this screen, and a couple of lines until
"starting dracut initqueue hook" and "starting Show PLymouth boot
screen"
(order may vary)
- after a couple of seconds, the laptop reboots
EFI boot not providing a menu means booting from USB is the only way
to
recover from such an issue, right ?
Alas, rescue mode breaks for me with
anaconda rescue is broken · Issue #5609 · QubesOS/qubes-issues · GitHub,
whether I try to boot with 4.0.4 or with 4.1-20210422.
What options do I have to recover ?
Answering to myself on this: using any rescue USB key to change the default
boot entry in partition 1 does the job, and we can then proceed with removal
of the kernel-latest package.
Then, is there a way with qubes-dom0-update to get intermediate
kernel versions to check when is started to break ?
Maybe there's a simpler way, but I could not list available versions using
dnf. So I selected one from Index of /r4.0/current/dom0/fc25/rpm/.
Then "qubes-dom0-update kernel-latest-5.10.8-1.qubes" does download the rpm
but fails claiming "No package kernel-latest-5.10.8-1.qubes available"
(looks like qubes-dom0-update - dom0 package updates are downloaded but not installed · Issue #4792 · QubesOS/qubes-issues · GitHub) and I have
to finish installing it by running dnf on the rpm file.
It seems older kernel-latest versions are not even in the dnf index, and I had
to wget them and transfer them manually to dom0, which is quite an ordeal
Of older versions of kernel-latest, unfortunately only 5.4.10-1 will boot
(tested in a quick manual bisect: 5.5.7-1, 5.6.16-1, 5.10.8-1). Older 5.5 and 5.6
get stuck at one point (probably in a loop, as fans start spinning faster), and
5.10 has a same reboot loop similar to 5.11.
Bottom line seems to be "no vfio for now in 4.0".
