Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 32
On-line CPU(s) list: 0-31
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 9 7950X 16-Core Processor
CPU family: 25
Model: 97
Thread(s) per core: 2
Core(s) per socket: 16
Socket(s): 1
Stepping: 2
Frequency boost: enabled
CPU(s) scaling MHz: 52%
CPU max MHz: 5879.8818
CPU min MHz: 3000.0000
BogoMIPS: 8999.60
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep
mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx
mmxext f
xsr_opt pdpe1gb rdtscp lm constant_tsc
rep_good amd_lbr_v2 nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl
pni pclmul
qdq monitor ssse3 fma cx16 sse4_1 sse4_2
x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm
extapic cr
8_legacy abm sse4a misalignsse 3dnowprefetch
osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext
perfctr_llc m
waitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba
perfmon_v2 ibrs ibpb stibp ibrs_enhanced vmmcall fsgsbase bmi1 avx2
smep bmi2
erms invpcid cqm rdt_a avx512f avx512dq
rdseed adx smap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw
avx512vl xs
aveopt xsavec xgetbv1 xsaves cqm_llc
cqm_occup_llc cqm_mbm_total cqm_mbm_local avx512_bf16 clzero irperf
xsaveerptr rdpr
u wbnoinvd cppc arat npt lbrv svm_lock
nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter
pfthreshold
avic v_vmsave_vmload vgif x2avic v_spec_ctrl
vnmi avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq
avx512_vnn
i avx512_bitalg avx512_vpopcntdq rdpid
overflow_recov succor smca fsrm flush_l1d
Virtualization features:
Virtualization: AMD-V
Caches (sum of all):
L1d: 512 KiB (16 instances)
L1i: 512 KiB (16 instances)
L2: 16 MiB (16 instances)
L3: 64 MiB (2 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-31
Vulnerabilities:
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Retbleed: Not affected
Spec store bypass: Mitigation; Speculative Store Bypass disabled
via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and
__user pointer sanitization
Spectre v2: Mitigation; Enhanced / Automatic IBRS, IBPB
conditional, RSB filling, PBRSB-eIBRS Not affected
Srbds: Not affected
Tsx async abort: Not affected
edwin ~ [4.14.1] ❯ cat /mnt/home/edwin/Qubes-HCL-
Gigabyte_Technology_Co___Ltd_-B650E_AORUS_MASTER-20230807-162029.yml
Qubes-HCL-Gigabyte_Technology_Co___Ltd_-B650E_AORUS_MASTER-20230807-162029.cpio.gz (11.2 KB)
