Sound and mic do not work out of the box, but you can make them work.
To make sound and mic work:
dom0: sudo qubes-dom0-update kernel-latest git tar automake libtool
Create new cube called “alsa-download”, and start a terminal in alsa-download vm.
In alsa-download:
git clone git://git.alsa-project.org/alsa-lib.git
cd alsa-lib
git checkout v1.2.6.1
cd …
tar czvf alsa-lib.tgz alsa-lib
git git://git.alsa-project.org/alsa-ucm-conf.git
cd alsa-ucm-conf
cd …
tar czvf alsa-ucm.tgz alsa-ucm-conf
In dom0:
qvm-run --pass-io alsa-download ‘cat /home/user/alsa-lib.tgz’ > alsa-lib.tgz
qvm-run --pass-io personal ‘cat /home/user/alsa-ucm.tgz’ > alsa-ucm.tgz
qvm-run --pass-io personal ‘cat /home/user/alsa-sof-firmware-2.0-2.fc35.noarch.rpm’ > alsa-sof-firmware-2.0-2.fc35.noarch.rpm
sudo dnf install alsa-sof-firmware-2.0-2.fc35.noarch.rpm
tar xzvf alsa-lib.tgz
tar xzvf alsa-ucm.tgz
cd alsa-lib
./gitcompile
sudo make install
cd …/alsa-ucm-conf
cp -r ucm ucm2 /usr/share/alsa1. Restart computer, and enjoy sound and mic. Make sure in dom0
**uname -a**gives you kernel version >= 5.15. -
Make sure every time you lose sound, or mic or both:
double check kernel version in dom0
**uname -a**gives you higher than or equal 5.15 -
in dom0:
cd alsa-lib
sudo make install
cd …/alsa-ucm-conf
Make sure
sudo dnf list --installed|grep alsa-sofgives you version 2.0.2 or higher**.** If not, execute step 3.2, 4.c, 4.d from above in that order.
Enjoy sound and mic!
Best regards
Robert
Qubes-HCL-Dell_Inc_-XPS_17_9710-20220212-104223.yml (958 Bytes)
