Can any one point me to why the following fails? I have been banging my
head against this for a while ...
--- SNIP ---
create bind dirs config file:
file.managed:
- name: /rw/config/qubes-bind-dirs.d/50_user.conf
- makedirs: True
- mode: 644
- dir_mode: 755
{% set binddirs = ['/usr/local'] %}
{% for binddir in binddirs %}
configure '{{ binddir }}' to be persistent:
file.replace:
- pattern: "^binds+=( '{{ binddir }}' )$"
- repl: "binds+=( '{{ binddir }}' )"
- append_if_not_found: True
{% endfor %}
--- SNIP ---
The corresponding error ("State 'create bind dirs config file' in SLS
'custom_dom0.sys-vpn-mpihlr_assert_vpn_setup' is not formed as a list")
is a complete red herring, as the so called first part by itself works
just fine and only fails when I add the latter (jinja) part ...
How do I properly deal with the single quotes in `pattern` and `repl`?
Thanks for any pointers.
Sincerely, Joh
