test to change it back to RAID mode and see. Put back on ACPI if it doesn’t help.
I tried to set up rapid (rst raid) but nothing has changed
Trying acpi = force is a good idea.
tried, but it didn’t help.
Actually this problem arose before this summer when I had to change the cpu fan and on the next restart I had the bios reset. This was in conjunction with the kernel version upgrade.
In fact I had to put ahci settings back on sata-operetion-mode and reselect the efi boot file.
for suspension is essential, the last step will be reinstallation.
Thanks for your ever present help.
sudo cat /proc/cmdline
root=/dev/mapper/qubes_dom0-root rd.luks.uuid=luks-625d19ea-61d4-408f-aec8-25f759724841 rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap i915.alpha_support=1 rhgb quiet acpi=force rd.qubes.hide_all_usb plymouth.ignore-serial-consoles rd.qubes.hide_pci=02:00.0 modprobe=xen-pciback.passthrough=1 xen-pciback.permissive xen-pciback.hide=(02:00.0)
sudo efibootmgr -v
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0001,0002,0000,0003,0004
Boot0000* xen HD(1,GPT,3a4fdaa2-0a2c-4783-ba2a-59a408c24c1c,0x800,0x64000)/File(\EFI\QUBES\XEN.EFI)
Boot0001* P0: Samsung SSD 850 PRO 256GB BBS(16,0x0)AMBO
Boot0002* Atheros Boot Agent BBS(20,0x0)AMBO
Boot0003* UEFI: Network Card PciRoot(0x0)/Pci(0x1c,0x5)/Pci(0x0,0x0)/MAC(e0db55a2173f,0)/IPv4(0.0.0.0:0<->0.0.0.0:0,0,0)AMBO
Boot0004* UEFI: Network Card PciRoot(0x0)/Pci(0x1c,0x5)/Pci(0x0,0x0)/MAC(e0db55a2173f,0)/IPv6([::]:<->[::]:,0,0)AMBO
[k8@dom0 0000:02:00.0]$
sudo cat /proc/acpi/wakeup
Device S-state Status Sysfs node
P0P1 S4 *disabled
USB1 S3 *disabled
USB2 S3 *disabled
USB3 S3 *disabled
USB4 S3 *disabled
USB5 S3 *disabled
USB6 S3 *disabled
USB7 S3 *disabled
RP01 S4 *disabled pci:0000:00:1c.0
PXSX S4 *disabled
RP02 S4 *disabled
PXSX S4 *disabled
RP03 S4 *disabled
PXSX S4 *disabled
RP04 S4 *disabled pci:0000:00:1c.3
PXSX S4 *disabled pci:0000:07:00.0
RP05 S0 *disabled
PXSX S4 *disabled
RP06 S4 *disabled pci:0000:00:1c.5
PXSX S4 *disabled pci:0000:09:00.0
RP07 S4 *disabled
PXSX S4 *disabled
RP08 S4 *disabled
PXSX S4 *disabled
PEG0 S4 *disabled pci:0000:00:01.0
PEGP S4 *disabled pci:0000:02:00.0
PEGA S4 *disabled
PEG1 S4 *disabled
PEG2 S4 *disabled
PEG3 S4 *disabled
XHC S4 *disabled pci:0000:00:14.0
HDEF S4 *disabled pci:0000:00:1b.0
EHC2 S0 *disabled pci:0000:00:1a.0
EHC1 S0 *disabled pci:0000:00:1d.0
LID0 S3 *enabled platform:PNP0C0D:00
sudo dmesg |grep -2i acpi
[ 0.000000] Linux version 4.19.142-1.pvops.qubes.x86_64 (user@build-fedora4) (gcc version 6.4.1 20170727 (Red Hat 6.4.1-1) (GCC)) #1 SMP Sat Aug 29 19:54:26 UTC 2020
[ 0.000000] Command line: root=/dev/mapper/qubes_dom0-root rd.luks.uuid=luks-625d19ea-61d4-408f-aec8-25f759724841 rd.lvm.lv=qubes_dom0/root rd.lvm.lv=qubes_dom0/swap i915.alpha_support=1 rhgb quiet acpi=force rd.qubes.hide_all_usb plymouth.ignore-serial-consoles rd.qubes.hide_pci=02:00.0 modprobe=xen-pciback.passthrough=1 xen-pciback.permissive xen-pciback.hide=(02:00.0)
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
journalctl -b -3|grep -i error
Sep 17 12:17:56 dom0 kernel: RAS: Correctable Errors collector initialized.
Sep 17 12:18:18 dom0 kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
Sep 17 12:18:23 dom0 libvirtd[1915]: 2020-09-17 10:18:23.083+0000: 1961: error : virConnectOpenInternal:1118 : no connection driver available for qemu:///system
Sep 17 12:18:25 dom0 libvirtd[1915]: 2020-09-17 10:18:25.778+0000: 1946: error : virPCIDeviceReset:1002 : internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
Sep 17 12:19:17 dom0 lightdm[3167]: Could not chown user data directory /var/lib/lightdm-data/k8: Error creating directory /var/lib/lightdm-data/k8: File exists
Sep 17 23:30:44 dom0 qubes.WindowIconUpdater-sys-firewall[3502]: xcffib.ConnectionException: xcb connection errors because of socket, pipe and other stream errors.
Sep 17 23:30:44 dom0 qubes.WindowIconUpdater-sys-net[3512]: xcffib.ConnectionException: xcb connection errors because of socket, pipe and other stream errors.
Sep 17 23:30:44 dom0 qubes.WindowIconUpdater-deby[3815]: xcffib.ConnectionException: xcb connection errors because of socket, pipe and other stream errors.
Sep 17 23:30:58 dom0 libvirtd[1915]: 2020-09-17 21:30:58.376+0000: 6590: error : virPCIDeviceReset:1002 : internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
sudo journalctl -b -3|grep -i failed
Sep 17 12:17:56 dom0 kernel: tsc: Fast TSC calibration failed
Sep 17 12:17:56 dom0 kernel: PM-Timer failed consistency check (0xffffff) - aborting.
Sep 17 12:18:18 dom0 kernel: cfg80211: failed to load regulatory.db
Sep 17 12:19:11 dom0 audit[3232]: USER_AUTH pid=3232 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:authentication grantors=? acct=“k8” exe=“/usr/sbin/lightdm” hostname=? addr=? terminal=:0 res=failed’
Sep 17 12:19:11 dom0 kernel: audit: type=1100 audit(1600337951.456:129): pid=3232 uid=0 auid=4294967295 ses=4294967295 msg=‘op=PAM:authentication grantors=? acct=“k8” exe=“/usr/sbin/lightdm” hostname=? addr=? terminal=:0 res=failed’
Sep 17 12:19:13 dom0 audit[3232]: USER_LOGIN pid=3232 uid=0 auid=4294967295 ses=4294967295 msg=‘op=login acct=“k8” exe=“/usr/sbin/lightdm” hostname=dom0 addr=? terminal=/dev/tty1 res=failed’
Sep 17 12:19:13 dom0 kernel: audit: type=1112 audit(1600337953.492:130): pid=3232 uid=0 auid=4294967295 ses=4294967295 msg=‘op=login acct=“k8” exe=“/usr/sbin/lightdm” hostname=dom0 addr=? terminal=/dev/tty1 res=failed’
Sep 17 12:19:21 dom0 qui-updates[3445]: gdk_window_thaw_toplevel_updates: assertion ‘window->update_and_descendants_freeze_count > 0’ failed
Sep 17 23:31:09 dom0 lvmetad[766]: Failed to accept connection errno 11.
Sep 17 23:31:14 dom0 systemd-cryptsetup[7614]: Failed to deactivate: Device or resource busy
Sep 17 23:31:14 dom0 kernel: audit: type=1130 audit(1600378274.172:331): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-cryptsetup@luks\x2d625d19ea\x2d61d4\x2d408f\x2daec8\x2d25f759724841 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=failed’
Sep 17 23:31:14 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-cryptsetup@luks\x2d625d19ea\x2d61d4\x2d408f\x2daec8\x2d25f759724841 comm=“systemd” exe=“/usr/lib/systemd/systemd” hostname=? addr=? terminal=? res=failed’
Sep 17 23:31:14 dom0 systemd[1]: systemd-cryptsetup@luks\x2d625d19ea\x2d61d4\x2d408f\x2daec8\x2d25f759724841.service: Unit entered failed state.
Sep 17 23:31:14 dom0 systemd[1]: systemd-cryptsetup@luks\x2d625d19ea\x2d61d4\x2d408f\x2daec8\x2d25f759724841.service: Failed with result ‘exit-code’.
