Hi!
Following the instructions how to remove obsolete templates, I have a problem with both old whonix templates. The problem goes like this:
[master@dom0 ~]$ rpm -qa qubes-template-\*
qubes-template-debian-10-4.0.1-201912251612.noarch
qubes-template-whonix-ws-15-4.0.1-201910102356.noarch
qubes-template-whonix-gw-16-4.0.6-202109211111.noarch
qubes-template-whonix-gw-15-4.0.1-201910102356.noarch
qubes-template-whonix-ws-16-4.0.6-202109211111.noarch
[master@dom0 ~]$ sudo dnf remove qubes-template-whonix-ws-15
Dependencies resolved.
awokd
November 21, 2021, 8:39pm
2
Ulrich Windl:
qvm-template-postprocess: error: No Qube with this name exists
Maybe try to fake it out by cloning some other template to "whonix-ws-15", then run again?
Hmm: The template is no longer visible in Qubes Mangager (I think I had deleted it from there).
[master@dom0 ~]$ rpm -ql qubes-template-whonix-ws-15-4.0.1-201910102356.noarch
/var/lib/qubes/vm-templates/whonix-ws-15
/var/lib/qubes/vm-templates/whonix-ws-15/apps
/var/lib/qubes/vm-templates/whonix-ws-15/apps.tempicons
/var/lib/qubes/vm-templates/whonix-ws-15/apps.templates
/var/lib/qubes/vm-templates/whonix-ws-15/clean-volatile.img.tar
/var/lib/qubes/vm-templates/whonix-ws-15/icon.png
/var/lib/qubes/vm-templates/whonix-ws-15/netvm-whitelisted-appmenus.list
/var/lib/qubes/vm-templates/whonix-ws-15/private.img
/var/lib/qubes/vm-templates/whonix-ws-15/root.img
/var/lib/qubes/vm-templates/whonix-ws-15/root.img.part.00
/var/lib/qubes/vm-templates/whonix-ws-15/root.img.part.01
/var/lib/qubes/vm-templates/whonix-ws-15/root.img.part.02
/var/lib/qubes/vm-templates/whonix-ws-15/vm-whitelisted-appmenus.list
/var/lib/qubes/vm-templates/whonix-ws-15/volatile.img
/var/lib/qubes/vm-templates/whonix-ws-15/whitelisted-appmenus.list
[master@dom0 ~]$ rpm -V qubes-template-whonix-ws-15-4.0.1-201910102356.noarch
missing /var/lib/qubes/vm-templates/whonix-ws-15
missing /var/lib/qubes/vm-templates/whonix-ws-15/apps
missing /var/lib/qubes/vm-templates/whonix-ws-15/apps.tempicons
missing /var/lib/qubes/vm-templates/whonix-ws-15/apps.templates
missing /var/lib/qubes/vm-templates/whonix-ws-15/clean-volatile.img.tar
missing /var/lib/qubes/vm-templates/whonix-ws-15/icon.png
missing /var/lib/qubes/vm-templates/whonix-ws-15/netvm-whitelisted-appmenus.list
missing /var/lib/qubes/vm-templates/whonix-ws-15/root.img.part.00
missing /var/lib/qubes/vm-templates/whonix-ws-15/root.img.part.01
missing /var/lib/qubes/vm-templates/whonix-ws-15/root.img.part.02
missing /var/lib/qubes/vm-templates/whonix-ws-15/vm-whitelisted-appmenus.list
missing /var/lib/qubes/vm-templates/whonix-ws-15/whitelisted-appmenus.list
