Additionally, the fc37 minimal does not have GUI terminal because of its nature of execution from formal installation of minimal setup. As a result, fc37 minimal only provides CLI based programs.
To withdraw my mistake, in order to install dbus x11, as an user:
1. sudo dnf install apt
2. add the Debian Buster package repositories to /etc/apt folder via root
3. After you are doing so, sudo apt update for the packages
4. sudo apt install [package]
