Hello friends,
Laptop w520 thinkpad corebooted.
I would like to be able to use an external monitor connected by the displayport.
This coreboot tutorial https://www.coreboot.org/Board:lenovo/w520
suggest to run the following command:
sudo ./util/nvramtool/nvramtool -w hybrid_graphics_mode=“Dual Graphics”
I tried it in dom0, but nvramtool is not installed, so this starts alarming. Looking for a way to install it found the following for Fedora:
sudo dnf copr enable starlabs/coreboot-configurator
sudo dnf install coreboot-configurator nvramtool
https://support.starlabs.systems/kb/guides/coreboot-configurator
https://starlabs.systems/
But here I doubt if it is worth going forward. First I do not know this Starlabs contributor. Do you know if they can be trusted? Second, even admitting to trust them how may I translate this “copr enable” into Qubes parlance, such as: something like:
sudo qubes-dom0-update copr enable starlabs/coreboot-configurator
Best
Franz
