I have noticed on Fedora, the cli prompt itself is not colourful although the rest of the output is. Is there a way to get the prompt itself in colour as well? The prompt on Debian is in colour, it makes it easier to find things when the prompt is in colour aswell.
Since this is not a Qubes-specific question, you might have better luck searching the web for how to do this in Fedora (or Linux in general) or asking in a Fedora (or general Linux) venue.
I wonder if this *is* Qubes specific, as it is stated that the Debian
prompt is in color. (Implicit, I think, is the suggestion that the color
matches the window decorations.)
OP - is that what you see? That the prompt is consistent with the window
decoration set by Qubes?
No the colour of the prompt does not follow the window decoration, I was wondering if this isn't maybe a problem only on Fedora on Qubes and not Fedora in general. I don't have a Fedora standalone I can check on. I just found it odd that the prompt on Debian would be in colour (Green, and it is real easy to find in between a lot of other output) and on Fedora it is the same colour as the text you type. But as I was re-reading my reply here I just had another look over and I just discovered that the prompt on some of the Fedora VMs is in colour, also a bright green, and some of them are default text colour. So in essense it doesn't have anything to do with Qubes. I am a little confused though because I can swear some of the VMs that I previously check where the prompt was the default text colour now has a colourful prompt. (head scratch head scratch)
I do see this in .bashrc on Debian and there is nothing of it in .bashrc on Fedora. There is in fact a lot of stuff in .bashrc on Debian that is not there on Fedora.
.bashrc
===truncated===
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
xterm-color|*-256color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
#force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
# We have color support; assume it's compliant with Ecma-48
# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
# a case would tend to support setf rather than setaf.)
color_prompt=yes
else
color_prompt=
fi
fi
===truncated===
I have copied it over to .bashrc on Fedora and uncommented `force_color_prompt=yes` but it makes no difference.
I use a custom color prompt for my bash shell. I had to use different methods in my Fedora and Debian qubes to get the prompt I wanted. It’s a little tricky because you have to check and see how the system files setup the $PS1 file. Because I wanted the same definition in each of my qubes I ended up creating a /etc/profile.d/custom.sh file to define the prompt in Fedora templates to set the prompt in each appVM based on that template. The code based on some adapted Debian or Ubuntu code. There is also a bunch of code to setup definitions for colors and other terminal escape sequences.
My custom.sh produces prompt like:
[user@docker-fed-37:2 Fri 2023-05-05 17:35 GMT /etc/profile.d]$
where
user@docker-fed-37 is green
/etc/profile.d is bright_blue
the :2 represents the terminal number where numbering starts with :0
===custom.sh===
# User specific aliases and functions
term-control-colors () {
# https://mywiki.wooledge.org/BashFAQ/037
# Variables for terminal requests.
[[ -t 2 ]] && {
alt=$( tput smcup || tput ti ) # Start alt display
ealt=$( tput rmcup || tput te ) # End alt display
hide=$( tput civis || tput vi ) # Hide cursor
show=$( tput cnorm || tput ve ) # Show cursor
save=$( tput sc ) # Save cursor
load=$( tput rc ) # Load cursor
bold=$( tput bold || tput md ) # Start bold
stout=$( tput smso || tput so ) # Start stand-out
estout=$( tput rmso || tput se ) # End stand-out
under=$( tput smul || tput us ) # Start underline
eunder=$( tput rmul || tput ue ) # End underline
reset=$( tput sgr0 || tput me ) # Reset cursor
blink=$( tput blink || tput mb ) # Start blinking
italic=$( tput sitm || tput ZH ) # Start italic
eitalic=$( tput ritm || tput ZR ) # End italic
[[ $TERM != *-m ]] && {
red=$( tput setaf 1|| tput AF 1 )
green=$( tput setaf 2|| tput AF 2 )
yellow=$( tput setaf 3|| tput AF 3 )
blue=$( tput setaf 4|| tput AF 4 )
bright_blue=$( tput setaf 12|| tput AF 12 )
magenta=$( tput setaf 5|| tput AF 5 )
cyan=$( tput setaf 6|| tput AF 6 )
# for broken termcap databases with 16 ANSI colors
# blue=$'\e[0;34m'
# green=$'\e[0;32m'
# white=$'\e[0;37m'
white=$( tput setaf 7|| tput AF 7 )
default=$( tput op )
eed=$( tput ed || tput cd ) # Erase to end of display
eel=$( tput el || tput ce ) # Erase to end of line
ebl=$( tput el1 || tput cb ) # Erase to beginning of line
ewl=$eel$ebl # Erase whole line
draw=$( tput -S <<< ' enacs
smacs
acsc
rmacs' || { \
tput eA; tput as;
tput ac; tput ae; } ) # Drawing characters
back=$'\b'
} 2>/dev/null ||:
# set local definitions
term-control-colors
# my_blue=$'\e[0;34m'
# my_green=$'\e[0;32m'
# my_white=$'\e[0;37m'
# my_reset=$'\e[00m'
color_prompt=yes
else
color_prompt=
fi
fi
if [ "$color_prompt" = yes ]; then
PS1='[\[$green\]\u@\h\[$reset\]:\l \D{%a %F %R %Z} \[$bright_blue\]\w\[$reset\]]\$ '
# PS1='[\[\033[01;32m\]\u@\h\[\033[00m\]:\l \D{%a %F %R %Z} \[\033[01;34m\]\w\[\033[00m\]]\$ '
else
PS1='[\u@\h:\l \D{%a %F %R %Z} \w]\$ '
fi
unset color_prompt force_color_prompt
===custom.sh===
Another alternative I explored is the setup the above or similar file in the appVM .bashrc.d file.
Unfortunately, the Debian default overrides any $PS1 string defined /etc/profile.d/custom.sh so I define and export a $CUSTOM_PS1 environment variable and then use it appropriately in my Debian .bashrc to set the $PS1 string. Also note that the term-control-colors function doesn’t work in Debian login shell and the “my_” variable definitions can be used instead.
