Hi all,
I would like to patch some sources of xen and would like to know how
to introduce the patches into the build system.
Regards,
Ludwig
Hi all,
Regards,
Ludwig
ludwig...@gmail.com:
Hi all,
There is a patch directory somewhere in the build environment where custom Qubes patches get applied to the Xen kernel. It may be inside the chroot filesystem, but I don't have a build VM handy to confirm. Run something like "sudo find -name *patch*" at the top level of your build machine and I think you can find it, then check the make file that applies the patches to add your own.
Put with the other patches in vmm-xen, and adjust xen.spec.in
